Hey guys i know its probably been asked before but i cant find anything specific in the search. i'm currently putting a rb20 into my 92 bmw. so far the mods for the motor are r33 turbo, custom intake plenum, front mount short plumbing, 255lph fuel pump, remap chip for the ecu. what i'm aiming for is about 300horsepower at the wheels. What other mods am i gonna need to get close or over my power aim, like bigger injectors or after market exhaust manifold, cams etc. i'm gonna run about 15-16 psi everyday and eventually forge the motor. any help appreciated cheers
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/
15-16psi on stock RB turbos = Epic fail 12-13psi is a safer (slightly) option
and from what ive seen rb25 turbos on rb20s will make around 200rwkw. 300hp is 225kws.
post up some pics of how it fits as ive been wondering about a conversion of this sort for a while.
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884588
the reason for rb20 is for one cost to start with and if/when this motor fails it will be getting a fully forged rb30det(rb25 head). and for now the 2 litre keeps my insurance down as i'm already payng heaps for a euro car. As for the turbo i will post pics of my mates bmw with an rb20 which is running the standard rb20 turbo and has been running 15psi for the last 18-19 months with no problems/smoke. The turbo willbe staying as is for a month or 2 till i can upgrade but my exhaust will be very custom so i'm chasing a turbo that will fit both my t3 flange manifold and the dump pipe
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884650
Yep you might get away with around 14psi since its on a 20, few people have and most you will see is 18xrwkw on an internally standard 20 thats in pretty good nick with supporting mods
I would suggest a second hand high flow if your not looking at spending a great deal
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884692
kool thanks guys might run 14 to start with till i get my hands on a second hand hiflow. any tips on where to find one/suppliers? the reason i was thining around that psi is mainly because my mate has been running 15psi for 18 months racing/ draging the car and has not had the turbo fail and it is only a standard rb20 one
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3884894
pffft 15psi is safe lol, yeh run 15 through it, then dont complain when the rear wheel falls off, and the front wheel then chews into the housing shattering the wheel putting metal peices into your intercooler or into your engine...
just do what is suggested... 12psi and save up for a highflow that you can push 18psi through.
maybe its just me, but id rather do things right the first time, even if your on a budget (even more so if your on a budget)
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3885572
the rb25 turbo isnt ball bearing is it? what other turbo's of standard cars will fit and be adequate? dont want to pour thousands into the turbo setup
rb25 turbo is ceramic, and isnt ball bearing unfortunately.
they cant/shouldnt take more then 13psi (11 to be uber safe)
as suggested, try the hi-flow option, or the hks 2530.
cheers
eddie
R33 turbo's are BB, i know this because i was told they were not and went out and bought a bush bearing rebuild kit for my S1 turbo only to discover once we got the turbo apart that they are actually a GT28 as opposed to the T28 which is a bush bearing.
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3885790
You will be able to run slightly higher boost with the rb25 turbo on an rb20 rather than an rb25 because of the engine capacity.. I did say SLIGHTLY higher tho.. :D
edit: i do agree you will probably struggle to get near 300hp with this setup..
Edited by nitestalkr
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3885937
Actually there a hitachi turbo not a garret....so they aint t28 nor gt28
Thats just basicly a rough size estimate that is given to them (the stock turbos)
obviously the turbo is the same as a garret then since MTQ use a T28 rebuild kit for them.
https://www.sau.com.au/forums/topic/220293-rb20-in-bmw/#findComment-3886045
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
