i had a look around and see a lot of oil forums but one on the N/A section and though i need to hear how everyones oil are going in there cars because there isnt anything new on engine oils here.
i brought Red line 10w40 high performance, all synthetic oil
apparently this does wonders
brought it for the new engine going in with about 50000km on it
spent $121 on 4.7liters because the bottles are in gallons (PFFH) haha
whats eveyone elses view on these top oils like royal purple and bla bla elf and yeh all that?
and what are hopeless fake oils?? :D
cheers, Andrew
https://www.sau.com.au/forums/topic/220328-engine-oils/
well im ing Nulon 10-40 fully synthetic and im glad i used it..... i won 5 litres last year at extreme horsepower for winning the 6 cylinder naturally aspirated dyno class.
i had heaps of people tell me not to use fully synthetic in a non turbo...but she has due for an oil change back in feb i think it was, and the oil is still see through now, starting to get a little bit dark. however if i had been using the :"normal" oil it would be as black as black by now and id probably be thinking of doing another oil chnge before it gets to the stage where it is so thin that it makes my oil pressure drop.
but yeah thats my 2 cents on what i use, im really happy with it and the car loves it......so im gonna keep using it :D
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3885617
that's generally based on a cost benefit factor. turbo's should use synthetic because they are sometimes oil cooled and the heat to cool cycle degrades the oil faster.
to the OP: that said it depends on your application. if you are cruising around a semi synthetic (dare i say natural) will be fine provided you keep using the same oil for your subsequent services. if you do a bit of dyno or track work like cara, myself and a few others then synthetic would be the way to go!!
royal purple, elf, motul, take your pick.
personally i run motul
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3885635
but yeah thats my 2 cents on what i use, im really happy with it and the car loves it......so im gonna keep using it :P
O ok i saw the nulon at the shop yesterday and it would have been my 2nd choice :)
i picked redline because lots of turbos are using it and i was thinking being N/A it will be like giving it a treat and the best thing for it, the guy at burson said i should use fully synthetic for the engines life now because mineral mixtures wont do the job after fully synthetics????
yeh reading the label it last for 30,000km and can oil a jet turbine so im expecting my pistions to be 100% ;) haha
i also heard the RB30de/t
jets blocked oil gallery's a lot so the oils there would be a fair bit of a important thinggg ???
anyways off to work now
cheers, Andrew :rofl:
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3886787
dunno i last used 20w 50 penrite in my 30e its done near 286,000 doesnt miss a beat... yeah its thick but thinner oil seems to make it run crap... i dunno why i last used 10w something didnt like it so im back to 20w 50 usualy use penrite or castrol both companys been round long enough
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3887992
personally i would use redline products for my transmission fluids.
regardless NAs won't be as fussy with oil as the turbo models... just make sure you find some nice quality one and don't mix and match. service them regularly and you should have no problems.
always keep in mind that these are 13-15 year old cars and yet we drive them like they had just come off the show room floor
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3888014
i use Nulon 15w-50 street and track high performance in the excel
usually about $50 for 5L - i only need 3.3L so i use 2 bottles for 3 oil changes
works well - oil is nicer colour after more and more oil changes as its cleaning more and more crap out...
i dont burn as much oil as i used when i was on Penrite15
something semi-synthetic/synthetic 5w-30 to 15w-50 should be fine for a n/a skyline
Fuchs Titan Super GTO
Nulon High Tech Fast Flowing
Nulon Street and Track High Performance
Castrol EDGE Sport 5w-30 or 10w-60
Castrol GTX3
Penrite HPR15 or HPR10
Penrite Sin10 or Sin15
Motul 4100 Turbolight
Motul 300V Power
Elf Competition GT 15w-50 or 10w-30
Elf Super Sporti XP 15w-40
thats all i can think of atm....
it also depends on the age of the engine - older, then a slightly heavier oil, newer, then a thinner oil
Edited by 342Four
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3888126
hmm thats the next oil for me for my manual gear box
apparently its 3.8 liters
but with the whole GTS4 thing i looked and there are about 3 topics on it in transmissions and they are all totaly different
does anyone know what type of gear box i have? simple GTS one? and any stats on it if its not the simple GTS one?
but being AWD i am pretty sure i have a transfer case.
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3891556
hey guys with the oil gauge..
issert best if its lower or higher up the meter????
and can someone explain further?
i use mobile 1... quite expensive, that with iridium plugs
omg even though im gonna sell it soon,
u gotta treat ur skyline with beautiful love !
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3891944
should sit about 2/3 up
and 1/3 is usually what it stays at for the first 5min in the morning, just because thats life and oil is thicker till the engine warms its self.
what specifically did you want to know but?
mobile 1 is good and so are iridiums, yeh being skylines they kill any spark plug faster than most cars so
looks like we are spoiling our cars :)
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3892016
Im thinking of using motul gearoil and for my diff to
everyone think this would be ok
also my heatshields rattle in my gearbox so there is a bit of wear and tear
eventhough its only 8 year old gear box :unsure:
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3896289
royal purple all the way. i used motol turbolight before till i got my hands on the royal purple. hard to come buy tho unless u know a machanic
What weight is your royal purple???
because i was looknig into i more than redline but i needed a 10w40
https://www.sau.com.au/forums/topic/220328-engine-oils/#findComment-3899560
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
