Make: Nissan
Model: R34 GTT Coupe
Milage: 95,000Kms
Transmission: Manual
Colour: Silver
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: 21,500 ono
Contact: 0413 654 321
Coments/Modifications: Very stock standard apart from a few nice additions. Inspected by Gavin Woods prior to purchasing and given a very clean bill of health. Alarm by Chris Rogers with built in turbo timer. Jim Berry R33GTR clutch installed 3000k's ago. Always serviced every 5000k's. C's Short Shift kit. Just fully detailed. DVD MP3 Head unit
more information on carsales:
http://www.carsales.com.au/used-cars/priva...amp;Make=NISSAN
  • 3 weeks later...
