Why? Because they don't have cameras to cover the whole carpark.. even in the most secluded corner
I park there almost every day for work... yesterday i got back to my car spot and she was gone... turns out some lowlife scum tried to steal my car... and failing that, stole another car.. used it to push my car down 2 levels of parking (no, no cameras picked this up at all.. noone saw it and noone reported it) to a secluded area of the car park... and stole my rims.. They left in the stolen car... star city managed to catch them leaving the carpark.. oh joy!
by the time i found the car it was balanced precariously on a jack on one side (in the middle of my side skrit so its now bent) and my spare tyre on the other side... the car was very unstable and was leaning a little on my front bar which is now cracked and broken
All up the f**kers got:
4x Work Emotion XD9 rims, 17x8.5 fronts, and 17x9.5 backs... one of the rims has 2 seperate sections of gutter rash on it
Powerfc ECU and hand controller - Serial number to be added
And some lame ass cds
If anyone comes across the above selling cheap (and I will find my ECU serial number to add to this), please let me know so I can pass the info onto the police.
Thank you.
Mona
  • Replies 77
Thats no good you would think with all the money they have that there well be cameras everywhere....
I always go star city for dinner and an occasional gamble lol never had trouble there thought it would be a very good sercue carpark now i will think twice...
And yeah its good your car wasnt taken
Oh crap.. not good Mona :D
Hope your bits turn up!
I've made it a habit to hide my controller under the dash since the prices of PFC have skyrocketed..
"star city managed to catch them leaving the carpark" - I guess you meant caught them on video, not caught them physically?
sorry, i meant they were caught on camera not physically caught.. i wish!
Yes there was an alarm.. thats the only reason they didn't take my car and settled for the next best thing. The reason the alarm didn't notify anyone is because, i believe, they were actually in my car the day before.. they disabled the noise box but when they tried to get my car yesterday, they still couldn't get through my alarm which pretty much imbolises the engine
My ecu and hand controller are not in sight.. the ecu is behind the kick panel in the passenger footwell, and my pfc has cabling into the glove box.. the assholes did not steal my radio, turbo timer, or boost controller or gauges.. they obviously wnated the car, and when they realised they werne't going to get it, simply took what they could as quickly as they could.. i suspect they opened to glovebox to find and take what was in there, and ended up finding the hand controller which they then traced to the ecu..
I'm always suspicious of the security guards at places like star city.. it just seems all a bit convenient that they get away with barely any trace. The thieves are either very stupid to be stealing from a place that is theoretically covered with cameras, or they know that they cant get caught because they're mates with the security guards or whatever.
I'm not saying that in this case the security had anything to do with at all, its just a conspiracy theory!
Hey mate i'm with you on this one, i slept in my car once at star city, my boys were gambling and it wasnt my thing, was buggered so i thought i'd have a nap in my car (r34), 10 minutes later a security knocks on my window asking if i' ok, told him i was just sleepy and waiting for my friends.
Wondered what would have happened if i wasnt in the car....
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
