god the internet is good for essay writing procrastination
agreed. just how I managed to find my way on here..
I usually fill up when I hit the line just before E, like the second last line. About 40-43L goes into my tank which does seem odd as its 65L if I'm not mistaken??
https://www.sau.com.au/forums/topic/220381-fuel-levels/#findComment-3886728
You should never run your tank under a quarter full, all pump fuel has sediment which sinks to the bottom of your tank and sits there contaminating the last few litres.
If you run the tank below 1/4 to may times you can clog and even damage the fuel pump.
Just some advice :rofl:
https://www.sau.com.au/forums/topic/220381-fuel-levels/#findComment-3887086
Got any proof of that Mick?
I imagine the fuel filter would get most of that before it does anything harmful besides it's not like the petrol would have that much time to settle as the vehicle is moving around.
Yes I do have proof actually, it happened to my R31 a couple of years ago... It conked out on the way to work and after I towed it to work and pulled the fuel tank and pump out (worked as a mechanic at the time - handy) the pump was covered in the same brown slime that was sitting in the bottom of the tank.
It wasnt rust either, the tank was spotless after I drained and cleaned it.
The fuel filter is after the pump not before it, the pump is exposed to whatever goes into your tank. The filter is there to stop whatever gets through the pump and lines from getting into the fuel rail and causing a blockage.
You would be very surprised at what is in most people's fuel tanks, especially if they use crap quality fuel... Even the best fuel stations can get contaminated fuel reserves, if the truck that transported it wasnt cleaned properly or the huge underground tanks are contaminated it all ends up going into some poor bastards car eventually.
https://www.sau.com.au/forums/topic/220381-fuel-levels/#findComment-3887125
I get 600km per tank highway driving. Thats with pertrol left in it, I didnt want to run it empty.
I think i am getting around 10ltrs to the 100+, cause i can get 10.5 to the 100km in canberra driving.
Edited by BNR32t
https://www.sau.com.au/forums/topic/220381-fuel-levels/#findComment-3896087
His car is running rather laggy turbos which do help when it comes to keeping the fuel usage down.
My old mans r33 gtst is getting around 10lts to the 100kms aswell, he gets 550kms before filling up and thats with heaps of fuel left. Stock turbo with mild mods.
https://www.sau.com.au/forums/topic/220381-fuel-levels/#findComment-3901626
to my knowledge the R33 gts-t's have a 45litre tank (correct me if I'm wrong)
Back on topic....
On average I can get around 400 - 450 untill i feel i really need to fill up (very close to empty) - usually fill up with 42-44 litres.
THe most I have ever been able to squeeze into my fuel tank was 46 litres with the fuel light on.
NOTE: I never squeeze more fuel in after the pump was clicked off if that makes sense
Edited by 33Sedan
https://www.sau.com.au/forums/topic/220381-fuel-levels/#findComment-3927708
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
