Wts - Cooling Pro Fmic Kit For R33 Gts-t
Item: Cooling pro type 2 FMIC Kits
Age: 1.5 years (not to sure)
Condition: Ok
Price: 180
To Fit: (What car) R33 gts-t (s1 or s2)
Contact: ricki via PM
Comments:
The cooler Kit comes complete with the core/all the piping/brackets/silicon joiners and clamps.
I recieved this from a mate who got a new kit for his car. I have had it running on my car for about 1 year and was working perfect.
As said above the core has some damage. There is a few bent fin blades here and there but thats with every Intercooler. The is also a small dint on the top of the core (i have pictures to show anyone who is interested)
Before i put it on my R33 i got it pleasure and leak tested and it passed 100% :D
The piping kit is in good nic except for the crossover pipe (the one that runs over the ran blade) the xover pipe has a dint in it and was cut and re welded to get the dint out. (i also have detailed pics of this also)
As said above the kit has been on my car for 1 year now and worked great. If you get an exhaust joint to make up a xover pipe to replace it, you would have a great kit for this price (however the kit is still workable with what it comes with)
Im only chasing about $180 (pp if interstate) for this kit as it does have some damage.
All interested PM me and i can send ya more pics.
Edited by Ricos
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
