the previous owner pretty much neglected the cleaning side of things, he forked out decent money for the rims, but never cleaned them, now it has many rust spots around them, specially on the deep dish on the rear, i purchased some mothers chrome polish, it made the chrome come up shiney, but didnt remove the small spots.
any ideas?
https://www.sau.com.au/forums/topic/220390-removing-rust-spots-from-rims/
Brasso?? I had polished SSRs with the same problem on my sprinter. Got on the brasso or similar (it was a mild cutting compount of some description, name escapes me at the mo) and that got rid of 99% of the rust, then polished the rims up and it came up good as gold. Might be something to give a shot.
Edited by AndrewJZX100
so what did you use Craig?
first used the brasso to take all the muck off with a rough side of an old sponge, then buffed it to a shine with mothers chrome polish.
theyre all nice and shiney now.
mines have little spots of tarnishing, like little grey patches in the chrome, anyone got ideas for that?
I've made stainless steel on the bike look like chrome with this stuff....recommended by chromers & pro polishers.
Where would it be easiest to find that stuff Pete?
This is were I got it from but there should be other paint supply shops around if you live out north.
Lonsdale Auto Paint Suppliers P/L
17 Sherriffs Road
LONSDALE SA 5160
8322 0030
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
