the previous owner pretty much neglected the cleaning side of things, he forked out decent money for the rims, but never cleaned them, now it has many rust spots around them, specially on the deep dish on the rear, i purchased some mothers chrome polish, it made the chrome come up shiney, but didnt remove the small spots.
any ideas?
https://www.sau.com.au/forums/topic/220390-removing-rust-spots-from-rims/
Brasso?? I had polished SSRs with the same problem on my sprinter. Got on the brasso or similar (it was a mild cutting compount of some description, name escapes me at the mo) and that got rid of 99% of the rust, then polished the rims up and it came up good as gold. Might be something to give a shot.
Edited by AndrewJZX100
so what did you use Craig?
first used the brasso to take all the muck off with a rough side of an old sponge, then buffed it to a shine with mothers chrome polish.
theyre all nice and shiney now.
mines have little spots of tarnishing, like little grey patches in the chrome, anyone got ideas for that?
I've made stainless steel on the bike look like chrome with this stuff....recommended by chromers & pro polishers.
Where would it be easiest to find that stuff Pete?
This is were I got it from but there should be other paint supply shops around if you live out north.
Lonsdale Auto Paint Suppliers P/L
17 Sherriffs Road
LONSDALE SA 5160
8322 0030
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
