APEXi products brand new from the Sole Australian APEXI Agents - Warranty and Tech Support
Brand new in box APEXi Power FC Units with Hand controller
Nissan Skyline R33 GTS-t (brand new) - $1650 delivered
Nissan Skyline R34 GTT (brand new) - $1540 delivered
Nissan R32 GTS-t AP Engineering FC (brand new) - $1650 delivered $1950 (with controller) delivered
Nissan Silvia/180sx CA18DET AP Engineering FC (brand new) - $1650 delivered $1950 (with controller) delivered
Nissan GTi-R AP Engineering FC (brand new) - $1650 delivered $1950 (with controller) delivered
Universal APEXi Power Intake Pod Filters
Universal Bolt up pod. Dry type pod only need compressed air to clean.
Available in -
OD 160 ID 85 (REPLACEMENT FILTER) - $89 delivered
OD 160 ID 75 (REPLACEMENT FILTER) - $89 delivered
OD 160 ID 65 (REPLACEMENT FILTER) - $89 delivered
OD 140 ID 75 (REPLACEMENT FILTER) - $89 delivered
APEXi Power Intake Panel Filters
Replace factory air filters with greater filtration and no need to replace just clean!
Available for all popular Nissan models and other manufacturers - $79 delivered
APEXi Power Intake Filter Kits -
pictured is R33 R34 GTR kit
Nissan GTR Skyline R32, R33, R34 Kit - $350 delivered
pictured is R33 GTS-t kit
Nissan Skyline GTS-t R32, R33 & R34 GTT Kit - $140 delivered
**Other Nissan vehicles available as well as other Manufacturers
APEXi DECS Tacho -
Main Features Include:
- Large, 120mm analog display for easy to read shifting points.
- Digital display built into the gauge face
- Classic EL (Electro-Luminescence) lighting
- Accurate RPM reading all the way to 11,000 RPM
- Progressive number design for better high RPM viewing
- Integrated TEMP, and Pressure reading*
- High intensity shift light included
- Versatile mounting bracket
- Available in white and black face
- $590 delivered
* Temp, and Pressure reading available only with the use of an optional Temp or Pressure sensor. Sensors sold separately.
  • 1 month later...
  • 1 month later...
Any Power FC's for r34 gtt? If not do you have any coming in and is it possible to put a deposit down for one?
I have a small handfull in next week monday
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
