You'll need a heat gun/hair dryer and a blade. Something like an emo blade, then heat and slice/carve away...
I've read a few stories of people trying to remove tint themselves and they've all recommended others to get it professionally done. Only $80 or so anyway.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3887375
i did mine my self
yes it can be a bitch but why pay some one money to do it when you can do it your self
as long as ur not a drop kick you'll be fine
i just ripped the tint off and used hot soapy water and sharp emo blades lol to get the glue off
it does take time but so what
and apparently there is this spray u can buy which you just spray on to the sticky stuff and u just wipe it off but i couldnt find it any where
hope this helps
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3887516
i thougth it was ok to have darker tint on the back and rear quarts. its just the drivers and passengers that have to be legal
A topic about tint came up in the Vic section a few months back and it's only legal to have the rear quarter windows dark. So pretty much the windows that the driver need to look through to drive can't be darker than 30% (I forget the exact number :D ).
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3889081
Easy!! Done it many times! all you need to do is peel the tint off and you will notice the sticky gluish residue on the window. this part is the bitch part. all you need is a spray bottle with water or window cleaner in it and a razor blade with a handle and start spraying and scraping away. it may take time but unless u want to pay someone to do it its gonna take alot more time to get your car checked.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3889382
i did mine my self
hope this helps
Time is money.
If its going to take me 3-4 hours of time, and fiddly at that
For $80, its money well spent and lets one do other things.
Fair enough if you sit @ home all the time and dont work/leave the house etc... DIY probably would be worth while... include purchasing blades, cleaners etc knock another $10-$15 off the price off someone with the tools doing it
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3890285
Hey thanks for the insight lads. I may just get someone do to it properly as time is quite tight at the moment.
Also, While failing me for tint they also got me for the child restraint brackets. They are in the middle of the speaker and "should" be in front of it. WTF do i do to fix that??
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3893307
If your car has been complied by an authorized workshop you will have no trouble passing with those child restraints where they are.
The fact the cops even picked on you for that is stupid. The workshop has all the certs/tests etc required to say that they are effective where they are.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3893315
It's all respective of the state you live in....
For NSW, the law is the rear windows and windscreen can be as dark as 5% tint, with NO tint on the front side windows, and only the top 10% of the front windscreen tinted as well (For business vehicles and taxis)
Or
All windows no darker than 35% tinting all around, but only the top 10% of the front windscreen tinted (for business vehicles, and taxi's).
For passenger cars, the NSW rules are no darker than 35% tint all around, and only the top 10% of the windscreen tinted.
This can be different for other states, and thus you need to check your local area.
As for the 2 defect issues, There is a spray you can get to break down the tinting glue, call up a local tinter and ask them the best thing to remove tint before you take it to them for re-tinting (if you take it or not is not their business, but if they think your making their life easier, it will help you get the information).
As for the restraints, they will be checked off on your compliance stickers.
Something everyone needs to remember is that a Police officer's "defect list" is not an actual list of defects on the vehicle, but a list of the things he believes should be checked by someone that knows the ADR requirements, and regulations of the local area. For a cop to ping you for stuff like this, either he didn't get his coffee and doughnut, or you didn't pass his personality test.
For an example, yesterday I took a highway patrol officer for a drive in my car, because he had never been inside a Skyline GTR in a 'civil' environment (off duty). He pointed out the lack of H-pattern on the gear lever (can place a sticker within 10cm of the gear lever to comply in NSW), and the twin POD filters under the bonnet, but other than those things, he said unless I really upset the officer, I would be sweet with.
He also mentioned a simple cover on the PODs will not surfice, as the legal requirement for NSW is a SEALED enclosuer for the pod filters.
Personally, I have heard mixed 'stories' about the child restraints, from rear speakers removed and restraint clips fitted, to restraint clips fitted stock BEHIND the speaker grills, but this is still debatable, and should be covered under the compliance of the imported car.
Good lock with everything.
B.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3893356
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
