You'll need a heat gun/hair dryer and a blade. Something like an emo blade, then heat and slice/carve away...
I've read a few stories of people trying to remove tint themselves and they've all recommended others to get it professionally done. Only $80 or so anyway.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3887375
i did mine my self
yes it can be a bitch but why pay some one money to do it when you can do it your self
as long as ur not a drop kick you'll be fine
i just ripped the tint off and used hot soapy water and sharp emo blades lol to get the glue off
it does take time but so what
and apparently there is this spray u can buy which you just spray on to the sticky stuff and u just wipe it off but i couldnt find it any where
hope this helps
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3887516
i thougth it was ok to have darker tint on the back and rear quarts. its just the drivers and passengers that have to be legal
A topic about tint came up in the Vic section a few months back and it's only legal to have the rear quarter windows dark. So pretty much the windows that the driver need to look through to drive can't be darker than 30% (I forget the exact number :D ).
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3889081
Easy!! Done it many times! all you need to do is peel the tint off and you will notice the sticky gluish residue on the window. this part is the bitch part. all you need is a spray bottle with water or window cleaner in it and a razor blade with a handle and start spraying and scraping away. it may take time but unless u want to pay someone to do it its gonna take alot more time to get your car checked.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3889382
i did mine my self
hope this helps
Time is money.
If its going to take me 3-4 hours of time, and fiddly at that
For $80, its money well spent and lets one do other things.
Fair enough if you sit @ home all the time and dont work/leave the house etc... DIY probably would be worth while... include purchasing blades, cleaners etc knock another $10-$15 off the price off someone with the tools doing it
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3890285
Hey thanks for the insight lads. I may just get someone do to it properly as time is quite tight at the moment.
Also, While failing me for tint they also got me for the child restraint brackets. They are in the middle of the speaker and "should" be in front of it. WTF do i do to fix that??
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3893307
If your car has been complied by an authorized workshop you will have no trouble passing with those child restraints where they are.
The fact the cops even picked on you for that is stupid. The workshop has all the certs/tests etc required to say that they are effective where they are.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3893315
It's all respective of the state you live in....
For NSW, the law is the rear windows and windscreen can be as dark as 5% tint, with NO tint on the front side windows, and only the top 10% of the front windscreen tinted as well (For business vehicles and taxis)
Or
All windows no darker than 35% tinting all around, but only the top 10% of the front windscreen tinted (for business vehicles, and taxi's).
For passenger cars, the NSW rules are no darker than 35% tint all around, and only the top 10% of the windscreen tinted.
This can be different for other states, and thus you need to check your local area.
As for the 2 defect issues, There is a spray you can get to break down the tinting glue, call up a local tinter and ask them the best thing to remove tint before you take it to them for re-tinting (if you take it or not is not their business, but if they think your making their life easier, it will help you get the information).
As for the restraints, they will be checked off on your compliance stickers.
Something everyone needs to remember is that a Police officer's "defect list" is not an actual list of defects on the vehicle, but a list of the things he believes should be checked by someone that knows the ADR requirements, and regulations of the local area. For a cop to ping you for stuff like this, either he didn't get his coffee and doughnut, or you didn't pass his personality test.
For an example, yesterday I took a highway patrol officer for a drive in my car, because he had never been inside a Skyline GTR in a 'civil' environment (off duty). He pointed out the lack of H-pattern on the gear lever (can place a sticker within 10cm of the gear lever to comply in NSW), and the twin POD filters under the bonnet, but other than those things, he said unless I really upset the officer, I would be sweet with.
He also mentioned a simple cover on the PODs will not surfice, as the legal requirement for NSW is a SEALED enclosuer for the pod filters.
Personally, I have heard mixed 'stories' about the child restraints, from rear speakers removed and restraint clips fitted, to restraint clips fitted stock BEHIND the speaker grills, but this is still debatable, and should be covered under the compliance of the imported car.
Good lock with everything.
B.
https://www.sau.com.au/forums/topic/220402-removing-tint/#findComment-3893356
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
