Hey guys anyone know where i could find 1 Blue "GT" Badge (NA Skyline) and the "S" badge for the hood. Some a**h**** debadged my car today =(, just makes me think why in the world would they wanna do such a thing! I assume wreckers and Nissan would sell them (but for a higher price). How much do they roughly go for anyone know?
Any help would be much appreciated =)
Alex
Edited by Alex G
https://www.sau.com.au/forums/topic/220426-debadged/
Never mind i searched a bit more and found my answer :D
Here's for anyone else if they need it
Jap Parts Plus W.A.
5-7 Jade Street
Maddington WA 6109
Tel: (08) 9493 2191
Fax: (08) 9493 1411
http://www.jappartswa.com.au/
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3887401
Yeh I have the same problem, somebody depadged my red/white GT badge... Sad sad world! I found that just jap sold some, but at 50 bucks a badge... I also went to a panel beater to see how much it would cost to fill in the holes and repaint it... 900 bucks! Goes to show a new badge isnt that expensive afterall...
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3887734
A-Spec in the city sell a few badges. quality is 'meh' though.
cheers for the info! :P
i checked their website out and they had none on there but ill go there soon myself to go and see if they got them.
what you mean by 'meh'? they arent genuine ones or......?
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3887877
damn! $900! you could get heaps of badges for that! :D
but in a way it might be better having no/nearly no badges on your car so people stop friggin stealing them but then with that they will aim to steal something else... :P
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3887886
Well he has a bunch in a cabinet so I havn't held them to see if they are plastic with some silver coating or metal, for example.
It's in Carillon City same corridor thingo as Boost Juice. Frankee is a champ though he won't rip you off. Nice little one stop shop if your not into branded products, but I am so it's not my thing lol.
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3887981
Get the red ones. They look better. I have them on my car, they look much better then the blue ones. I didnt put them on, so you cant blame me :P And I dont think its the same as putting GT-R badges on it... Altho... Replace them with GT-R badges? :D
blues are for NA and reds are for turbo just in case u din know :)
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3888005
Yeh I know that Bernard, but mine came with the red ones when I bought it, and I think they look much better then the blue ones. I'm not hiding the fact that its NA, there are other things that give it away: The 4-stud rims, the lack of forced induction, the fact that i lose EVERY race... :)
https://www.sau.com.au/forums/topic/220426-debadged/#findComment-3890065
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
