does this sound normal? Ive connected a laptop to consult port and using a free program for logging. When the car is cold, the timing fluctuates around 0-5, but once its warmed up and idling on 700-800rpm, it sits at 0. Then at 2krpm goes to 25, 3krpm 35, 4krpm and + to 42. Not going higher then 42. Is this too high? I have a timing gun somewhere i can use on the weekend to verify (never used it before).
Other values im getting MAF idle at 1.06 volts, 2krpm 1.49v, 3krpm 1.88v, 4krpm 2.18v
coolant is 86c.
This is free reving the car, not under load.
https://www.sau.com.au/forums/topic/220439-correct-timing-using-consult-port/
