seller has no idea
it's not 'M Tune' it's M-spec, and that isn't one: an M-spec is basically a V spec 2 with a factory Robson leather interior and suspension more suited to the European market.
No there is no such thing as a Nismo M-tune.. there is however a Nismo M-spec.. maybe he made the bodykit himself and is dubbed the M-tune.. which would explain the 'rare' part.. or maybe its rare cause there are 0 recorded Nismo M-tune GTRs'...
In the car sales add its a only a V-Spec,
V-Spec's had smaller Nissan badges and the the "V-Spec" is a sticker only. Which is what this car is.
IF it was a M-Spec Nur, it will be based apond the V-Spec II Nur models.
Larger Nissan badge and a "V-Spec II Nur" as a badge. Usually its a Millenium Jade Colour with N1 running gear.
The bonnet should have a NACA Duct as with all V-Spec II came with. V-Spec's did not come with a NACA Duct.
M-Spec Nur's came with black leather interiour and a gold stitching trims with softer suspension for a more smoother luxury ride.
Edited by (00)SKYLINE(00)
  • 1 year later...
As I'm currently looking for a GTR, this one is still advertised and it was last updated by the seller on 13 December. So this isn't a 2002 VSpec 2 hey? This would be an older car? Thanks All.
Edited by Godzilla GTR
The 2002 M-Spec R34 GT-R did 'not' come out with the NACA Duct as did other VS-IIs.
The bonnet is aluminium 'not' C/F as with other VS-IIs. Believe it or not...
Leather - Yes
Power heated mirrors - Yes
Heated Front seats - Yes
Softer (fine grip) steering wheel - Yes
Ripple Control shockies for smoother ride - Yes
Softer Stabiliser -Yes
Typical VS-II rear stoppers - Yes
But... hang on...
Notice the pedals? Not typical VS-IIs in shape are they? Left foot rest is not aluminium either.
And as mentioned earlier, all M-Spec GT-Rs should have the larger/thicker NISSAN badge on the boot & this one doesn't.
Now Terry's puzzled...
Check the one on www.powerplayimports.com if you like?
Thanks Terry, this is an unusual one.
Cheers.
Leather - Yes
But... hang on...
^^^ Obtain the VIN# - Tell us what the "VIN Fasted" check reveals won't you?
With that check, also ascertain whether or not it comes from Northern Honshu or Hokkaido (re: possible rust from salted roads)
Sure will do. That M-Spec at Powerplay looks nice. I'll enquire on that one.
Cheers.
That seller has no clue about the real Nismo Tuned engines. There are 4 Nismo engine variants with an R34. They start with the S1, then R1 and the pinnacle is the Z Tuned motors. But in between the R and Z Tunes, Nismo decided to make one called a Fine Spec engine and only 70 of them were made in 2009. All sold out quite quickly.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
