Yes please. I just want to see how it looks on a skyline when it's installed. Just the front view is enough. It seems this style of FMIC isn't very popular in the market as i can't really find pictures of it on the internet.
Edited by teng
Thanks R-SPEC.
no probs
Totally off topic R-Spec that R34 looks bloody hot! I usually hate any imports in red but that looks great!
thanks :bunny:
where can I find an ARC return flow cooler?
preferrably an alternative to stealing R-SPECs one..
lol my kit wont fit your rb20 :down:
if you want a good deal on an arc kit let us know...
  • 3 weeks later...
Abu, when you get a ARC return flow cooler, please post images of it here.
Thanks.
No worries, I currently run a blitz turn flow so if you want I can post pictures of that
Blitz ones are probably a little bit easier to get your hands on over an ARC and possibly a little cheaper also
Heres a full DIY install of the arc cooler, looks alright, but in my opinion the cooler is far to small, hence why you can see the end tanks and piping when the bumper is fitted which is a bit ugly.
http://www.skylinesaustralia.com/forums/R3...html&hl=arc
Here's mine with the ARC Turnflow FMIC Installed. Uses stock mountings and didn't even have to relocate the horns. Just a bit of bumper grill cutting. Overall installation job time, 6hours cause i had to sand and paint the front bumper bar as it's all rusty. Same goes for the under car, all rusts. Needs lots of sanding then painting. That's what you get when you buy a car that is over 9 years old and has over 200k on the odometer. lol
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
