  • Replies 40
Posted Images
Dont forget you run the risk of your paint cracking when they roll it. Thats why they'll never garantee it.
Try a different offset rims maybe?
ill take the risk, im quite happy with the rims, and cant really afford changing them over and bla bla bla
still no one has any good places in mind???
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890211
No need to get someone to roll your guards.
The tools you'll need are a heat gun, jack, a yellow pages book and a friend.
Heat up your guard where you want it to be 'rolled', jack car up, put yellow pages book in between guards and tyre, lower the car, start jumping on the car with your mate to 'pull' the guard out a little. Take book out and look at work. If you did it properly, it should no longer rub.
I'm not being a dickhead or anything about what I just posted. I've done it myself because the rubbing was so bad and the technique I used (and many other people) works.
Edit: Here's a picture of how mine went out. The tyre was originally sitting on the guard, or guard was originally sitting on the tyre. I used a pretty think book and this is how it turned out. The gap is too big now. :)
Edited by adam-__-
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890264
how thin [or thick(not sure of your typo)] was ur book exactly?? was it one of these little sh*tty yellow pages??
if i do consider doin this i dont wanna screw it up
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890478
$50 a corner....thats cheaper than I have been quoted elsewhere, and I have to travel miles to get there..what hours are you guys available?
how much do you charge to borrow it?
and after it screws my paint and body work, do I get the hook ups with a reputable pannel shop that does good work for cash? LOL
Edited by 33gtst
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890951
I first off used that sized book, but once I finished, it still rubbed so I tried it again with an extra book in between the gap, now it's too big... :P
Best thing to do would be to get a guard roller, but if you can't wait, the newspaper roll technique works and it doesn't crack your paint (it didn't on mine).
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3890992
i rolled my gaurds with a steel pipe
put the pipe in between the tyre an gaurd, depending on how much u want it rolled depends on the angle you put the pipe on (slightly=more horizontal heavy=more vertical)
start from one side of the tyre an fit the pipe inbetween the gaurg an tyre, the get a mate to push ur car forward, which then the pipe will move along with the tyre which then you push down to get your gaurd the way u like it...
if your not keen, habib above me has a good price..
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3891331
paint will only crack/peel if the guards arent heated properly...
best i got quoted was $80 for the rears
i'm just gonna heat em up and push em in with my hands
so where did u get this quote from?? sounds good
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3891365
Yep, I did this with my rear guards. Just make sure you've got a solid pole. I crushed 2 poles out of 4 trying to roll/flare my rear guards.
https://www.sau.com.au/forums/topic/220461-rolling-guards/#findComment-3891367
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
