  • Replies 40
Posted Images
One side is perfectly flat on the inside, the other isn't so good. I used 3 or 4 different poles on the first one cause I've never done it before so it didn't come out as well. It's out of the way, but it's not perfectly flat like the second guard.
No before or after pics of actual guard, sorry.
Edit: This picture kinda shows how it is,
Edit edit: Another from outside view, can't even tell it was done by a pole :down:
Edited by adam-__-
Parallel, I used the softer part closer to the guard and tyre. I think I've got a picture of the front's 'newspaper' role job.
Edit: Don't know if you can see it that clear,
and before, again, not a really good picture to show you, but that's all I have. :down:
Edited by adam-__-
The 'newspaper roll' is what the technique of using a book or something like that to roll your guards is called. I actually used a small yellow pages book, like the one posted above somewhere, a old science book from yr5, some Vietnamese text book a while back and I think it was some history book. hahhaha. Just to make it nice and thick.
I prefer the pole once you have a good pole. hahha. I used all sorts, one was too weak, it broke in the middle of its job, another just died on me, the rest were too long. If you had the right length and strength pole, definitely go for pole. The yellow pages/book/newspaper roll technique wasn't too bad either, but it doesn't push the lip FLAT against the guard. I did it on the front because of all the tabs hanging out. It did the job, should get a proper roller to finish it off though.
i think i understand you
so the spine of the book will be resting on the inner edge of the tyre
yea i think i'll get a baseball bat as i hear they dont crush as easy
thanks for the tips tho champ
haha no worries.
What car are you planning on doing this on? Don't do it on a skyline in my opinion. The only reason I did it was because I've never done it before and it was on a cheap car. Get a proper guard roller, they're only $150 from Bursons and do the work yourself! Then maybe you can lend it out to me once you're done with it. :blink:
Adam - Just checking but you know with the newspaper roll your supposed to unbolt the bottom of the strut yeh? No need to use a yellow pages or anything silly.. just a normal sized newspaper.
Why do you have to unbolt the strut? I just did it with the suspension components untouched. :blink:
I didn't bother using a newspaper because it's too thin and it just gets 'sunken' into the tyres when the guard starts to bend out. The tyre just pushes in once the guard reach the tyres. It might work with those of you with low profile tyres, but I'm running 185/55 tyres and the guard sinks in. It sinks in and once you raise the car again, the guard hasn't even moved from original position.
Hope that made some sense.
Edited by adam-__-
Ah I see where you're coming from by saying unbolting the strut now...
Only problem is that my car's suspension isn't the same as skylines. When I undo my bottom strut bolt, nothing changes until I take it off the lower control arm and once it's off that, the whole wheel will come out, it's no longer 'attached' to the car. I'll get a photo if I don't make any sense.
Newspaper roll out back would be alright though, but I used the pole first. I would've just taken my springs out and let the car's full weight sit on the tyre.
Edit edit: Another from outside view, can't even tell it was done by a pole :woot:
I dunno dude; dont wanna sound mean or anything but that looks full dodgy and if someone recommended i did this to my skyline id be thinking they lost their mind :D ...but i suppose since its an el cheapo car then i can understand :)
I hope ppl understand there's a difference between needing ur guards rolled, and needing em flared.
I found that 4mm thick 1.5" ID steam pipe to be best for rolling guards. To help get a good flat roll, use a heat gun to warm the paint and get some of your generously proportioned friends to sit/stand/lay/drape, etc over the corner you wish to roll. Worked a treat when I did it years ago.....
yours is on a ke yea?
im goin to do this on a s13
im from syd.... so what is burson?
lol
thanks!
Yeah, ke70. haha
Bursons are a hardware store, something like Repco, Supercheap Auto, but they've got a wider range of things to choose from.
I dunno dude; dont wanna sound mean or anything but that looks full dodgy and if someone recommended i did this to my skyline id be thinking they lost their mind :) ...but i suppose since its an el cheapo car then i can understand :woot:
hahah I don't recommend people to do this on a skyline at all. It is dodgy and I only did it for some experience. Cheap car, so doesn't really matter what it looks like.
Edit: My guards don't look too bad compared to these guards.
Edited by adam-__-
    • For something like this, I'd skip just going for the cheapest, I'd find the place with the best experiences people have had, especially for restoration work. Like everything, there is upholsterers, and then there is upholsterers. Some really great upholsterers for automotive restos won't even appear to have an online presence.   My guide would be find some of the old school classic cars that have been fully restored and are immaculate, and ask the people who own them who did the work on their seats
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
