Hi all,
I have an r34 sedan non-turbo (not using turbo brakes like in the GT-V).
My rotors are in need of being replaced soon and I'm tossing up between slotted rotors or just the plain (genuine) ventilated rotors. I want to know if it is worth spending extra for the slotted rotors (DBA 4000 series) or if I'm just wasting my hard earned $$$. I'm intending to do all 4 corners. I mainly do city/freeway driving, on the odd occassion i take my car out to the Black Spur or the Great Ocean road for some fun (guys in Victoria would know these places :P )
Also wondering if there is a difference on the life of the rotor (slotted vs plain).
What are the recommended pads to go with the rotors? I was thinking bendix ulimates or would these be too harsh on rotors...
If your going to the trouble of changing the rotors, i would just put in slotted...
You really only need them in the front... however it does look better if you do all 4, and not just 2.
I dont think they are that much more from memory...
Just dont get the ones with the holes in them... augmented i think they are called, as disc around the holes tend to get fine line cracks due to rapid heating and cooling.
so ya +1 for slotted!
There are 4 types. Plain (no grooves or holes), slotted (grooves), drilled (holes) and slotted and drilled (obvious, isnt it?)
Slotted wear your pads down a lot more, but drilled are more prone to cracking. However, the drilled do allow for more venting, so they do serve a purpose
DBAs have a reputation for cracking, even their slotted rotors. I think most of the people doing it are doing it on the track though.
If you're only doing GOR and the Spurs you should be OK. I would assume, and hope, that you're not pushing your car to the limit on either road and overheating your braking hardware. There's not much margin of error available on either road, and with GOR especially help can be very far away.
Thanks for the tip about the rotors cracking - its got me thinking :)
I try to be gentle on the brakes where i can by using a lower gear.
I wonder if anyone else here has experienced cracking fo non-track use?
Thanks for the tips guys. I've bitten the bullet and going for DBA slotted "4000 series" up front and DBA slotted "street series" for the rear. They are on order, I'll update you guys on what I think of them.
get slotted and drilled mate look so much better and a lot better performance, you will not have any dramas with them cracking unless your thinking about drifting or track days ?(unlikely being n/a)
You can also get them cryo dipped (ask your brake specialist about this)
+1 Slotted and Drilled (countersunk)
i havnt really heard much of a difference between the 2 unless u doin some serious racing but my point of view standered ventalated is arite. plus now brake pads dont use aspesdos anymore they use fine metal particals in the brake pad so rotars dont last as long as they used 2. slotted do look better if u got money go for it if not just go normal cause rotars some are luky to last 80000km.
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
