Here's what I still got up for sale
Will upload more photo's when I get an opportunity to take em.
A Z32 AFM + Plug. It's been in Australia from Japan for not more than a month, is in pristine condition, and is the cleanest used AFM I've seen. Contains both meshes and plug has plenty of length - sold pending payment
Blitz BOV on Hotpipe for R33 GTS-T - $150 Delivered
RB20DET 80mm AFM + Blitz SUS Pod filter - $150 Delivered
444cc injectors from R32, R33 GTR Skyline, RB26 DETT - $250 Delivered
Stock R32 GTS-T RB20DET Manual transmission ECU - $150 Delivered
2 Pair-sets of foglights, one in pure brilliant white, and one in amber. Great working condition, almost regret getting an aftermarket front bar as I can no longer use these. They work fantastic (they'll take out an eye if you angle them up) - $80 a pair
Clear/white indicators (rectangular type). Perfect, unused, still in the box. - sold pending payment
A complete front bar for a Nissan Nissan 180sx SR model with teardrop indicators in factory green, also has foam backing, headlight brackets and underskirt. A small kink on the undermouth lip, but easily straightened with a heat gun - $100
A damaged front bar (damage on drivers side) with undermouth lip removed for a fmic, damage can be repaired with an abs welding kit, one teardop indicator (passenger side) - $3.22
Great condition pair of S14 front seats, clean as a whistle, no rails - $200
S15 rear 5-stud conversion and brake setup, contains calipers, rotors, uprights, hubs, cables and hoses. Fantastic condition, came from a mint s15 with very low km's. Factory pads got massive meat and rotors are barely worn. Perfect for those chasing a 5-stud conversion without going drum brake setup - $350
S13 front and rear brake setup. Contains calipers, rotors, hubs, uprights, hoses, cables, and front lower control arms. Great upgrade for ca18, came off my car in perfect order - $200
R32GTR Brake Master Cylinder, could do with a clean, other than that, great working condition - On hold
Most prices are negotiable
Pm me
Phillips
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
