Item: HKS racing badges.
Age: brand new from overseas
Condition: brand new.
Price: $20.00 each or $35.00 for both.
To Fit: any car. (What car)
Contact: 0401-237-422 or PM
Comments: Bought them from overseas and are brand new!
Grab these off me cheap... pickups welcome otherwise will post at buyer's expense (postage won't be more than $5).
These are rare now and look great - comes with 3M adhesive backing tape for easy application.
Cheers.
https://www.sau.com.au/forums/topic/220486-hks-badges/
umm these are not genuine, so you cant say that they are rare.
ive got the same one, so ye
Well, they're rare as you can't really get them any more... hence rare.
https://www.sau.com.au/forums/topic/220486-hks-badges/#findComment-3889328
Theres a stall out the front of the pet shop/ suga / boost juice area in chaddy that sells hundereds of diffrent custom badges... including these... I bought a fake gtr badge and an apexi one to put on my gf's 1.0L charade for 8 bucks together! :wave::/
https://www.sau.com.au/forums/topic/220486-hks-badges/#findComment-3908537
ill grab one mate where are you located? im in tullamaine and work in st kilda>
regards,
Cheers.
https://www.sau.com.au/forums/topic/220486-hks-badges/#findComment-3908822
regards,
Hey fellas,
Honest to god, I bought it off someone on ebay a couple of months ago - it worked out to be around $35 delivered so that's why I'm just trying to get what I paid back. However, if you guys think it's over priced, then fair enough I guess I got done then. Not trying to rip anyone off - but fair enough, if that is the case then I'll let them go for $10 bucks each ($20 the pair).
Ash - if you're interested mate, PM me...
Thanks fellas.
https://www.sau.com.au/forums/topic/220486-hks-badges/#findComment-3909532
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
