Hi all, very good read.
I also have a 2 door R34 and have so far purchased clear side indicators and will be looking to buy clear front indicators...
So far, if you dont want to wait for nengun, either Kudos or Slide seem to be doing fron indicators cheaper than JustJap.
Hope this helps.
Anyone organising a group buy? I would like to order a set of Clear Nismo Fronts.
Thanks
P.S. Clear on black isnt rice :D Yum Yum
  • Replies 73
Posted Images
Looks like my package arrived from Japan .. missed the courier though :wub: so I'll have to wait until monday arvo to pick it up. Does anyone know how to change the front and side indicators on an R34?? For some reason I assumed it'd be a simple process but having had a look at the indicators on the car, I wouldn't have the slightest clue where to start. Does the front bar have to come off completely to replace the front indicators ? What about the sides ?? Cheers
SunnCoast - performance-wise (ebay or google his webpage url) gave me a REEEEALLY good price on the indicators/nismo mats and gear knob. It's probably a better price than any group buy could do. So get in touch with him.
By the way, I went smoked :( Should look good I reckon ..black skyline, dark indicator, black plates. Yay, I'm getting there.
Edited by Delta Force
Black, White & Silver coloured cars are neutral in colour.
So Smoked or Clear lenses go with all of them.
But I also tend to go for Smoked lenses on a black car; or Clear lenses on a silver car.
Are your GTT side lenses flush with the body panel like an R33 GTST or do they stick out like a GTR?
If they stick out, the lens is spring loaded and so, with a screwdriver you push the indicator towards the front on the driver's side - and you push the lens towards the rear on the passenger's side.
Cheers
On the front bar of the R34 GTR they are spring loaded too, and you'd need to manoeuvre the lens to one side before it pulls out with say a suction cap of a GPS holder.
Cheers
For the Side indicators: Just pop them out and change the indicator and bulb. Very easy and pop them back in, takes about 5 minutes.
For the front indicators: Use a screwdriver and cloth to wedge it out of the spring thing, just apply a lil bit of pressure and when it pops out you can just use your hands to pull it out a lil bit more.
Be careful when putting in the bulbs, I was a newb and broke one caused it sprang back out. lol
Ah ok thanks guyd .. didn't realize it was a spring mechanism. Yeah the sides should be easy I reckon. Can anyone tell me which way to push the front indicators to release them?
If its the same as the GTR, you get a screwdriver with soft microfibre wrapped over the tip and push the indicator on the driver's side towards the front.
Repeat on the passenger's side but from the front, you push towards the rear.
The spring is not a metal spring! The housing itself should be spring-loaded plastic.
As the previous post said, be a bit careful with the front ones so that you don't scratch the paint.
You'll be an expert in 5 minutes - I expect!
Cheers
Can you please explain what you mean by "push the indicator on the driver's side towards the front" ?? How can you push the front indicators towards front/rear when they're sitting perpendicular to the car ie. can go only left or right .. or maybe I'm just slow.
from what i gathered from the above posts they just mean to push the actual indicator, the whole thing with the screwdriver toward the back of the car for the passenger side, and toward the front for the drivers, i havent tried this myself but sounds pretty straight forward, just try not to use too much pressure
Hi! Back again,
It's perfectly ok to ask...
I've had a look at pics on the net of a R34 GTT and it looks as if the position and type of indicator is the same as mine or for the R33 GTR for that matter...
If you are replacing the Driver's side indicator, you stand with your hip against the driver's door. You can then push your screwdriver against the side edge of the indicator lens and the whole of the indicator lens moves towards the front of the car. As it does so, the indicator lens starts to pop out.
On the other side, you stand with your left hip against the wheel arch and use the screwdriver against the leading edge of the lens & push it towards the rear of the car before it pops out.
There may be a bit of resistance at first depending on how much grit has lodged behind the indicator but you'll feel the springiness sure enough.
Hope that helps,
Terry
yeah i got that part about the side indicators .. I just don't know how to get the front indicators (on the front bar) out. I've read somewhere else that you have to open the bonnet up and push them from inside the engine bay towards the outside - atleast on an r33 I think. Does that sound right?
Congrats Den, on the sides!
Now it looks from the net that the GTT front indicators are the same set up as the R34 GTR.
In that case, you get a mobile phone/GPS windscreen suction cup and attach it to the driver's side lens. Then use the flathead screwdriver (wrapped with a little microfibre) and insert it on the inner or radiator side; but only till you can have enough leverage to push it sideways to your left (towards the wheel) and it should pop out as it's spring-loaded too. The suction cup can be used to pull out the whole housing without having to use the screwdriver as a lever and end up damaging the paint.
Cheers,
Terry
Just a quick question ..does anyone know where I might pickup a cheap suction cup ??
Hi Den,
Any mobile phone accessory shop will have a cheap mobile phone/gps holder with suction cup.
You can use it later from the top of windscreen on the passenger side to hold the top of a Sony Handycam; support the Handycam from the side window with a stem of a tripod with another suction cap; and support the Sony Handycam from underneath with a tripod sitting on the passenger seat and PRESTO YOU HAVE A CAR CAM !!! And it sits really still as you go up and down the mountainsides
Cheers
found a really cheap bathroom suction cup with a hook at bunnings .. $4.50 or so. Should do the trick.
Interesting note about the camera ... not sure if I'm into that though heh :happy: I am thinking of getting a gps thingy soon as they're very cheap and I hate using the crappy old paper UBD. But I wanna get one with bluetooth built in so I can use mobile hands-free at the same time on it.
Just tried to unclip the side indicators and they came out real easy, a bit TOO easy. It probably takes 10 sec each to take them off. A bit worried someone might try and help themselves to my indicators so I'm thinking of putting some glue in there when I put the new ones in. What do you reckon?
Hi Den,
That might depend on what suburb you live in I think. I probably would't fret about it since even garden variety Camrys and Fords & GMs can come with clears nowadays.
Clears look great though eh? Did you get smoke or clears? Doesn't matter - I put smoke on my black car and clears on my silver Honda.
Tell me when you come up to the Blue Mtns; for a coffee and a run - preferably not at the same time!
Coffee and carpet don't mix
Cheers,
Terry
PS Can give you a disk copy of an R34 Workshop Manual
I got the smoke ones ..should look fantastic I reckon (black car too). Got personalized (silver text on black background) plates coming in by the end of the week hopefully too. Now all I need is to get the bilstein suspension and lower the car 2cm (stock springs), fix a couple of rattles and I'm sweet for a while :happy:
Thanks for the invite .. I'll take you up on that next time up that way. Cheers
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
