Hey Guys,
Havent had any luck finding the Stagea S1 ECU pinout.
I have an SAFCII and want to fit it myself but dont have any pinout info.
Can anyone help me with this?
Thanks in advance!
Ben.
http://www.skylinesaustralia.com/forums/Ap...60&start=60
page 4
see my link
download the english instructions for the safc and stagea
all the info is around here mate, just got to search.
for a full ecu print out do a search for "secret squirrel trick" for the power-fc wiring to a S1 stagea ecu.
https://www.sau.com.au/forums/topic/220505-s1-ecu-pinout/#findComment-3888518
Didn't have any luck with the "secret squirrel trick" search.
Can anyone confirm that the ECU pinout in the DIY section under series 2 pinouts is the one for my 1997 series 1 RS4T? (confusingly the engine is referred to a series 2 RB engine but that's another story).
I understand that the Series II stagea has the R34 ECU but that the series I has a number of different ECUs. But do they all have the same pinout arrangement? I have followed a number of trails all over this site without a definitive answer. If anyone can supply a pinout diagram that they have used for their Series I stagea and know to be correct that would be great.
https://www.sau.com.au/forums/topic/220505-s1-ecu-pinout/#findComment-3893159
no be careful. there are 3 ecus/different pinouts in series 1 stageas. build dates and part numbers are in this thread. the workshop manual only shows the first pinout http://www.skylinesaustralia.com/forums/R3...html&hl=ecu
https://www.sau.com.au/forums/topic/220505-s1-ecu-pinout/#findComment-3893857
Yes, thanks...read the thread. My ECU is 23740 OV300 so I will assume that is as per the manual and as per the R34 pinout for s2 Stageas. Will cut wires one at a time and test. Would be good if you didn't have to make like a detective and people could post up the three pinouts that go with the three series1 ECUs under the thread for series 2 ECU pinouts.
https://www.sau.com.au/forums/topic/220505-s1-ecu-pinout/#findComment-3895048
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
