Hi,
Ok so when I rip off my turbo coolant lines again, I'm going to do a coolant change aswell.
I can't find any recommendations on the type of coolant to use, only that the R32 maintenance thread says use a 50:50 anti-freeze /anti-boil mix (I don't need anti-freeze, I'm in brisbane). Is this a glycol coolant? or non-glycol coolant? What ratio glycol (g/L)? Autobarn said that depending on engine/head material (cast iron vs alloy/aluminium) will need different types of coolant to stop corrosion, etc...
What brands do people use? I'm just looking at one of those 1L bottles that makes up to 10L.
Castrol?
Tectalloy (sp)?
Fixxxer
https://www.sau.com.au/forums/topic/220508-which-coolant/
Brisbane is colder than sydney in the morning!!!
Anyways to the point pickup some nulon mix up crap and some distilled water mix it up a little higher at 60:40 (60% nulon 40% WATER) \
NULON is recommended by alm,ost all mechanics
https://www.sau.com.au/forums/topic/220508-which-coolant/#findComment-3888388
Be careful mixing coolant stronger than 50:50. It's job is to prevent corrosion, lower the freezing point and raise the boiling point but it isn't as good at transfering heat as pure water. Making the mix too strong can reduce the effieciency of your cooling system.
Edited by _Scotty_
https://www.sau.com.au/forums/topic/220508-which-coolant/#findComment-3888419
I use,
TECTALOY 100 PLUS
Tectaloy 100 Plus is a pre-mixed 50% Anti Freeze/Anti Boil, ready to use second generation organic radiator coolant. Formulated for heavy duty long life use, it is designed to offer the maximum cooling system protection possible. Tectaloy 100 Plus is ideally suited to late model and high performance vehicles.
It is recommended as a replacement for factory fill coolants.
AUSTRALIAN STANDARD:
AS 2108-2004 "TYPE A"
COLOUR & LIFESPAN:
DARK GREEN, 4 YEARS/100,000 KMS
PART NO & PACK SIZE:
RETAIL: 1LT BOTTLE (TE1001L), 5LT BOTTLE (TE1005L)
TRADE: 20LT CONTAINER (TE10020L), 205LT DRUM (TE100205L)
https://www.sau.com.au/forums/topic/220508-which-coolant/#findComment-3888709
According to Nulon more = better cooling properties.. I believe they suggest 70% for best cooling i.e race conditions Im not sure why (I may be wrong as its from memory - which has prooved several times to be pretty unreliable.)
https://www.sau.com.au/forums/topic/220508-which-coolant/#findComment-3889554
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
