Make: nissan skyline
Model: R33
Milage: 150,000k's
Transmission: manual
Colour: maroon/burgundy
Complied? yes
Currently registered? rego till feb 09
Price: $14,000
Contact: 0424 143 184 or email me at [email protected]
Comments / Modifications:
General
Factory Type M bodykit (Front bar, side skirts and rear pods)
Nismo clear side indicators
Nismo leather gear knob
R32 GTR wheels (16 x 8 +30 lightweight forged aluminium)
Power
Kakimoto HyperMega Dual N1 Catback exhaust (dual 2.5" pipes from the cat into dual 4" cannons)
BOS Importing (Batmbl) Split dump/front pipe
Catco stainless core 5 inch body high flow cat
ARC R34 SMIC
Remapped ECU by Toshi (no speed limit, no rich and retard, optimised A/F ratios and timing)
FET Coil packs
Turbotech boost controller
Nismo fuel pump
Drivetrain
Nismo GMAX Twin plate clutch and flywheel
Short shift kit
Handling
Full Sydneykid suspension package -
Bilstein dampers with adjustable height circlips
Whiteline Springs
Whiteline adjustable swaybars
Whiteline adjustable camber & castor bushes
Whiteline pineapples
Whiteline dust covers and bump stops
Genuine GTR rear strut brace
JJR Front strut brace with brake cylinder brace
Hicas lockbar
Stopping
DBA 4000 slotted rotors
Winmax 0-600 degree pads
Electrics
Earthing kit
Adjustable shift light
Remote central locking, alarm and dual immobilizer
Images:
these photo's were taken just after i clayed and waxed it.
currently has a set of 19" chromys on, i still have the gtr rims so i can sell with either, ill take some more photo's this weekend with the 19's on
https://www.sau.com.au/forums/topic/220510-nsw-r33-skyline-for-sale/
  • 3 weeks later...
  • 3 weeks later...
PRICE DROP: $12,500
car is now located in castle hill as i have just moved down. i can meet anywhere in sydney if needed
Edited by weeman1
  • 1 month later...
price drop $10,000
brand new toyo R1R's all round, had exhaust leak but all fixed now cost over 600 to fix (broken stud bolts etc, all fixed now tho).
located in castle hill so come have a look, i can drive anywhere in sydney if need be
regards
mitch
Yeah, I know that, but the general population don't :laugh:
Has the timing belt been done? major service? logs? receipts? any issues at all with the car? tyres tread?
Sorry for all the questions dude!
hey mate,
timing belt was done before i bought it, i bought it with 120k on it, ive serviced the car every 5000k's myself since ive owned it, dont have any receipts for the work done on the car as the previous owner done all the mods, if you like you can pm him about the car, im sure he'd be happy to answer any questions you have about it, his name is tuitahi (drew) on these forums. no issues with the car now as ive just had the exhaust fixed up, had a bit of a leak. ive just put the new Toyo R1R's on 2 weeks ago so there's still plenty of tread left on them.
forgot to mention, theres some slight damage to the front left guard, as the old wheels i had on the car damaged it a bit as they were too big. shouldn't cost to much to get fixed, i just haven't got round to doing it yet
if you want to come round and have a look your more than welcome, give me a call on 0424 143 184, ill be home all day tomorrow
  • 1 month later...
  • 6 months later...
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
