I have all genuine BNR 32 GTR gear for sale.
I have a GTR front bar in midnight blue, i scratch down the bottom
Genuine GTR rear spoiler midnight blue, perfect condition
Genuine alloy GTR bonnet, damaged, white, repairable
GTR genuine grill, white, missing a couple clips, (still stay with cable ties) and you cant tell haha
Prices::
Front Bar $600
Wing $300
Bonnet $150
Grill $50
will post interstate at buyers cost
NEGOTIABLE on ALL prices
contact me via pm
help me fund my next project haha (and get off defect)hahaha
Pics upon request
https://www.sau.com.au/forums/topic/220519-genuine-gt-aaaar-gear/
bonnet take a hit from the front, didnt like the speed limit sign (haha) it is fixable, i will get a quote this week.
and yes min prices are negotiable (cheaper if you pick it up) pm me with ur offer ont he GTR bar
i need this stuff gone asap, willing to do cheaper if it is picked up this week, and all items can be viewed when necessary.
thankyou.
yes it is GENUINE hence not fibreglass hence it is PLASTIC
the thing is strong and light, wont dissapoint and rad33, if the bar sells, i will talk to you about the rad support
I WILL TRADE the front bar for a aftermarket style bar,
preferably Do-Luck, i dont want vertex or uras, and cash my way if its fibreglass
tell me what u got and i can work something out.
and i will swap the gtr wing, bonnet and grill for a GT Wing or similar style, (carbon fibre not aluminium)
Hey buddy, just a heads up on the GTR wing. I've got a silver one thats been for sale for half the price and hasn't had any interest yet so you may be asking a touch too much. Either way, it's not mine so it's not my decision but just thought it may be of interest.
Cheers.
thanks for the words but all depends wat state ur located in buddy
coz for u to ship urs sumwhere will cost heaps more then for me to ship it somewhere.
Hey mate did you sell the grill??
got lip but no slots. who needs em anyway ahah there just for show
the front bar pretty much touches my front mount so there is very little space for the air to go anywhere else.
some one buy it.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
