Item: RB25DET
Age: brand new engine
Condition:
Price: $12000 or best offer
To Fit: (What car) anything you want to bolt it to
Contact: dgarage@bigpond.net.au or via PM
Comments: Full engine package including...
Crack tested bored honed and decked block
Crankshaft linished and balanced with JUN collar fitted
Eagle forged conrods
Aries forged pistons
Total seal piston rings
ACL race series engine bearings
N1 oil pump
N1 water pump
Gates timing belt
OS giken exhaust cam gear
fully reco'd head
256/264 HKS camshafts
Painted engine covers
HKS exhaust manifold
Garrett T04Z turbo
Tial 38mm external wastegate
Plazmaman inlet plenum
850cc SARD injectors
Malpassi fuel regulator
Engine will be sold complete as a drop in, turn key option.
With correctly set-up fuel system and tuning this engine will be good for around 400KW at the wheels.
This engine was recently assembled by another workshop but suffered extensive blow-by due to incorrect clearances. He has gone to a full house RB26 so we are rebuilding it correctly and offering it for sale. Any reasonable offer will be considered including discount for exchange engine.
As a guide we just built a similar long engine (no turbo, manifold, gate, plenum, injectors and reg.) for NYTSKY that came to around $15000. So this represents significant value for money.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/220530-fully-built-rb25/
This engine setup was offered to me when Paul and i first got together with my build. As i had already bought all of the parts needed for my build i declined. But i was kicking myself after i got off the phone with him as for the price, you will not get anywhere near what this package can offer.
And the fact there is no waiting,set backs and the hassle of the car being off the road for any length of time, this is a very good deal!
Good luck with it Paul.
P.S Swaps on the turbo setup??? :P
willing to freight to perth
how would it be to send to postcode 6164
cheers
no problem...you arrange freight...our pick-up postcode is 2290
also forgot to add the plenum comes with 80mm billet throttle body
$8000 for long engine only with STD cams and prepped RB26 rods.
  • 4 weeks later...
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 馃ぃ
    • Perfect! Thanks for this, both look like great options!
