  • Replies 96
1.13 at Wakefield in a stock 33 with street rubber? You are either an excellent steerer or that was hand timed
Car has been remapped - 196kw.. yes street rubber.. but yea still stock turbo.. no engine mods (apart from pod filter lol)
Was timed by a proper lap timer (infra red or something)
www.ultra-lap.com
check it out :D
Edited by siddr20
Thanks guys, cheers!!
Dave - hahah Ive got more race tape on it now also so its getting more nuggetie lol
Thanks Jon for the adjustment lol
Sid - on my 1st time there in the dry (2nd time, 1st time was pouring rain with 1:20) I did a 1.14, If I remember your friend drove your car to get that 1:13? :D
but yeah, plenty room for improvement and yeah, love it, gone through M2 tunnel 3 times now also hahaha
1:20's or bust? lol - I'll just aim for a 1.12
I might even go straight line and try the drags and see what she'll do!
They will for superlap Vic! They are being saved! lol
Sid - the stockies - yeah they go ok! But now got some r32 GTAAAH rims (thanks to Vic!)
It needs Gary (sydneykid) to get my suspension set up sorted 100% lol
Exhaust is 3 inch front/dump - high flow cat and 3 inch exhaust with only 1 muffler...
I think it could be the gain with the EBC why its dropping off?
nice one mate. I knew you would not be disappointed with the GTRS. HKS gear never fails to impress. That thing should rock with 260rwkw. It will be very quick on the track with that nice fat responsive curve. making nearly 200rwkw at 4000rpm is kick ass.
and dave, mate 12:1 AFR is not lean at all?! dunno where that came from. that is a nice safe AFR.
also, thank god for primordial for the rotating. chubbsy mate, it's just one little button click!
Cheers Rich!
hahah yeah, I sence a failboat photo being posted because I failed at rotating lol hahaha
p.s. I still wanna drive the silvia!
Evil, The bleed off of boost is prob either due to wastegate (which I assume is external, so shouldnt be) or your BOV which is venting early. GTST ones does, if its aftermarket tighten up the spring and ull prob be right..
Gain would be controlling boost spike and it would be causing the car to jump from 12 to 14 .. you know the deal with spikes...
Hope that helps
Edited by DECIM8
Hey Nath, Its internal gated. Oh, standard BOV, and is nice and quiet and plumbed back still!
Oh, and your question on the 1st page - Id certainly give Unigroup a call and have a chat with Yavuz about the tune and what you want from your car!
Cheers!
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
