  • Replies 96
Cheers Rich!
hahah yeah, I sence a failboat photo being posted because I failed at rotating lol hahaha
p.s. I still wanna drive the silvia!
yeah mate, you're welcome to anytime, but I think your beast may be faster than the silvia now! you might be dissapointed with my girly 230rkw next to your far more manly 260... but I guess the little silvia does have a weight advantage.
though thomas drove the silvia yesterday and it certainly put a smile on his dial.
Chubbs, someone said before that the reason you're loosing up the top end would be cause of wastegate (doubt that as it's brand new) or the Bov... the standard GTR Bovs are a great little upgrade for our cars and can hold a bit more pressure before releasing any air... and, although it's heresay and some say it's a straight out lie, our bovs are designed to leak just a little bit as standard... some say for smoother gear changes, I say I have no idea why :P
Might be worth looking into though :)
Man, your car just keeps getting better and better!
Cheers Doof!
Although Im not reallly fused at the moment about the boost dropping off - its just awesome to drive even on 14psi!
GTST - kit is everything - turbo, lines, bolts, studs, jap instructions lol
prices range from around 2.6k to 3k but I wont say what I paid lol
Oh, I even saw them advertised on a performance website for 3.5k!!
ouch...
If the gate came with the turbo (btw how much did the kit cost?) then I doubt its the wastegate as its designed for it.
It has to be the bov, get a greddy plumb back then you can adjust how much presure to hold much better option than any gtr bov as its a 10pound spring which youd require a little more. second hand same damn price.
Yavuz should know. You can test the bov by blocking it off with a piece of aluminium but it could just be the boost controller not set up right or not enough preload on the wastegate actuator.
Anyways, regardless, you wont care for a couple of months at least. :P:(:)
Evil, The bleed off of boost is prob either due to wastegate (which I assume is external, so shouldnt be) or your BOV which is venting early. GTST ones does, if its aftermarket tighten up the spring and ull prob be right..
Gain would be controlling boost spike and it would be causing the car to jump from 12 to 14 .. you know the deal with spikes...
Hope that helps
no wrong.. you need to understand the mechanics of how it works and you will realise this is just because its a boost conrol issue. and nothing more.
wasnt aware that a "gtrs bolt on" evan had an option for a external waste gate :P
no wrong again.. dude learn how shit works THEN make a input on the issue.
this ones free :) a bov has a spring yes? it has one chamber with said spring pushing the valve closed with the engine not running.....
it has a chamber with a diaphram generaly twice the surface area of the valve its self..that is conected to the inlet manifold via a hose.. soooo that when the engine is running the chamber has manifold vacume acting on it..
and when its on boost it has boost acting on it.
so whatever your engine is doing the bov has either boost or vacume controling it. now.. when an engine is on boost, it has BOOST and THE SPRING keeping the valve shut.
ie: regardless of what boost you have the bov has BOOST and THE SPRING acting on the valve.... generaly at a 2/1 ratio. so with 10 psi on the valve diaphram it will require 20 pound to overcome the valve.. and thats without the spring!! so unless you have 30 pound boost in the piping and 10 in the manifold it wont leak.
the spring adjustment is there SOLELY TO ALLOW THE VALVE TO BE CRACKED OFF ITS SEAT AT IDLE. to avoid "flutter" and "reversion" on airflow meter equiped engines.
i use gtr bov on my engine. the bleed of at 12 pound, with no vac line attached. and with it ive no problems sealing 28 pound.....
chris your problem can be 2 things, most common is the actual setting on the boost controler. (if its electronic)
or the turbo is running out of puff. by looking at the graph id say is more the setting but could be the turbo reaching its limmit.
cheers :D
:thumbsup:
give him a break... he doesn't own a line anyhoo... :blush:
poor guy is driving zeddles these days... although I have spied his head being worked on atm :cool:
Sooooo Chris, back on topic.... how much more fuel are you going through seeing you are prolly spooling your turbo all the time atm!!! hehehe
I chewed through the first 2 tanks so fast just cause I wanted to hear the "whistle" all the time :D
    • Cool to see you're on the forum man, think you've met my twin brother a few times (Brent).
    • Yeah...but NA Mercedes V12.
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
