  • Replies 96
Cheers Rich!
hahah yeah, I sence a failboat photo being posted because I failed at rotating lol hahaha
p.s. I still wanna drive the silvia!
yeah mate, you're welcome to anytime, but I think your beast may be faster than the silvia now! you might be dissapointed with my girly 230rkw next to your far more manly 260... but I guess the little silvia does have a weight advantage.
though thomas drove the silvia yesterday and it certainly put a smile on his dial.
Chubbs, someone said before that the reason you're loosing up the top end would be cause of wastegate (doubt that as it's brand new) or the Bov... the standard GTR Bovs are a great little upgrade for our cars and can hold a bit more pressure before releasing any air... and, although it's heresay and some say it's a straight out lie, our bovs are designed to leak just a little bit as standard... some say for smoother gear changes, I say I have no idea why :P
Might be worth looking into though :)
Man, your car just keeps getting better and better!
Cheers Doof!
Although Im not reallly fused at the moment about the boost dropping off - its just awesome to drive even on 14psi!
GTST - kit is everything - turbo, lines, bolts, studs, jap instructions lol
prices range from around 2.6k to 3k but I wont say what I paid lol
Oh, I even saw them advertised on a performance website for 3.5k!!
ouch...
If the gate came with the turbo (btw how much did the kit cost?) then I doubt its the wastegate as its designed for it.
It has to be the bov, get a greddy plumb back then you can adjust how much presure to hold much better option than any gtr bov as its a 10pound spring which youd require a little more. second hand same damn price.
Yavuz should know. You can test the bov by blocking it off with a piece of aluminium but it could just be the boost controller not set up right or not enough preload on the wastegate actuator.
Anyways, regardless, you wont care for a couple of months at least. :P:(:)
Evil, The bleed off of boost is prob either due to wastegate (which I assume is external, so shouldnt be) or your BOV which is venting early. GTST ones does, if its aftermarket tighten up the spring and ull prob be right..
Gain would be controlling boost spike and it would be causing the car to jump from 12 to 14 .. you know the deal with spikes...
Hope that helps
no wrong.. you need to understand the mechanics of how it works and you will realise this is just because its a boost conrol issue. and nothing more.
wasnt aware that a "gtrs bolt on" evan had an option for a external waste gate :P
no wrong again.. dude learn how shit works THEN make a input on the issue.
this ones free :) a bov has a spring yes? it has one chamber with said spring pushing the valve closed with the engine not running.....
it has a chamber with a diaphram generaly twice the surface area of the valve its self..that is conected to the inlet manifold via a hose.. soooo that when the engine is running the chamber has manifold vacume acting on it..
and when its on boost it has boost acting on it.
so whatever your engine is doing the bov has either boost or vacume controling it. now.. when an engine is on boost, it has BOOST and THE SPRING keeping the valve shut.
ie: regardless of what boost you have the bov has BOOST and THE SPRING acting on the valve.... generaly at a 2/1 ratio. so with 10 psi on the valve diaphram it will require 20 pound to overcome the valve.. and thats without the spring!! so unless you have 30 pound boost in the piping and 10 in the manifold it wont leak.
the spring adjustment is there SOLELY TO ALLOW THE VALVE TO BE CRACKED OFF ITS SEAT AT IDLE. to avoid "flutter" and "reversion" on airflow meter equiped engines.
i use gtr bov on my engine. the bleed of at 12 pound, with no vac line attached. and with it ive no problems sealing 28 pound.....
chris your problem can be 2 things, most common is the actual setting on the boost controler. (if its electronic)
or the turbo is running out of puff. by looking at the graph id say is more the setting but could be the turbo reaching its limmit.
cheers :D
:thumbsup:
give him a break... he doesn't own a line anyhoo... :blush:
poor guy is driving zeddles these days... although I have spied his head being worked on atm :cool:
Sooooo Chris, back on topic.... how much more fuel are you going through seeing you are prolly spooling your turbo all the time atm!!! hehehe
I chewed through the first 2 tanks so fast just cause I wanted to hear the "whistle" all the time :D
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
