hey all
after having my 25 rebuilt and with the intention of installing hks 256/8.8 mm in let and 264/9mm exhaust cam my engine builder instructed me to install 90 pound spring to help with high boost and valve float when larger turbo will be installed so i thought ok go for it.
the problem that i am having now is that after a while when the motor has not been run on initial start up the hydraulic lifters are noisy. engine has been run in and being driven every day with good quality oil. has any one else experienced this problem b4? are there any other causes that would be making this problem evident?
Lifters weren't bled when put in by the sounds of it.... assuming there is no oil supply problem to the head???
Mine were noisy as a mofo for the first week on cold starts.... now I only have a slight noise(one stubborn lifter) which is slowly disappearing... been around a month since mine turned key on the new engine..
U can run a thin oil and take it for a nice long hardish drive and get some oil up into them.... ie high revs... low gear ... under speed limit of course for an hour or so :)
oooooooor take it to a track day and give it a good work out :)
were your lifter replaced when you put the cams in? if not, how many hms do they have on them?
im assuming your engine builder checked the clearences and just didnt slap them in the head
wasnt aware you can "adjust" the clearance of a hydraulic lifter.............
they are very hard to bleed, and most peeps dont really want to pay for new lifters.
as above what anna said :)
the lifters where soaked in oil the hole time the engine was apart for roughly 3 months .
the engine has been running for about 4 months now and still the same.
yes the price of new lifters is way to much atm .
the engine originally done some very high k's
  • 3 years later...
well Im assuming they would of been cleaned, but Im concerned the 90lb springs arnt helping with allowing the hydraulic lifters to function, not oiling up as soon as they could....
90lb is a heavy valve spring yeah???
Im not sure of the brand, 90lb is alot, performance springs dont even know where they would find a 90lb spring to fit....
65lb was recommended... 90lb will cause lifter issues apparantly...
Yes they do say couple mins at warm up stage then all goes quite.
Its just the noise that is annoying.
Confirmed with machinist about spring tension and they are NOT 90 Pounds .My bad for the incorrect info.
They are 65 pound springs as he has installed them in other 25 heads with no problems, it must just be the lifter's worn out and not sealing the
oil in the lifter.
New Lifters a must.
Other then the lifter problem, all is sweet.
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
    • looking forward to your t56 swap man its a game changer if it works!
