hey all
after having my 25 rebuilt and with the intention of installing hks 256/8.8 mm in let and 264/9mm exhaust cam my engine builder instructed me to install 90 pound spring to help with high boost and valve float when larger turbo will be installed so i thought ok go for it.
the problem that i am having now is that after a while when the motor has not been run on initial start up the hydraulic lifters are noisy. engine has been run in and being driven every day with good quality oil. has any one else experienced this problem b4? are there any other causes that would be making this problem evident?
Lifters weren't bled when put in by the sounds of it.... assuming there is no oil supply problem to the head???
Mine were noisy as a mofo for the first week on cold starts.... now I only have a slight noise(one stubborn lifter) which is slowly disappearing... been around a month since mine turned key on the new engine..
U can run a thin oil and take it for a nice long hardish drive and get some oil up into them.... ie high revs... low gear ... under speed limit of course for an hour or so :)
oooooooor take it to a track day and give it a good work out :)
were your lifter replaced when you put the cams in? if not, how many hms do they have on them?
im assuming your engine builder checked the clearences and just didnt slap them in the head
wasnt aware you can "adjust" the clearance of a hydraulic lifter.............
they are very hard to bleed, and most peeps dont really want to pay for new lifters.
as above what anna said :)
the lifters where soaked in oil the hole time the engine was apart for roughly 3 months .
the engine has been running for about 4 months now and still the same.
yes the price of new lifters is way to much atm .
the engine originally done some very high k's
  • 3 years later...
well Im assuming they would of been cleaned, but Im concerned the 90lb springs arnt helping with allowing the hydraulic lifters to function, not oiling up as soon as they could....
90lb is a heavy valve spring yeah???
Im not sure of the brand, 90lb is alot, performance springs dont even know where they would find a 90lb spring to fit....
65lb was recommended... 90lb will cause lifter issues apparantly...
Yes they do say couple mins at warm up stage then all goes quite.
Its just the noise that is annoying.
Confirmed with machinist about spring tension and they are NOT 90 Pounds .My bad for the incorrect info.
They are 65 pound springs as he has installed them in other 25 heads with no problems, it must just be the lifter's worn out and not sealing the
oil in the lifter.
New Lifters a must.
Other then the lifter problem, all is sweet.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
