I had a big fuel economy thread a while back plenty of info in it.
In summary
90% city driving I get btwn 320-400 depnding on how i drive the thing using about 60L of fuel. You can go well past the E line and then go for another 20-30kms when the light comes on.
I found the best economy to be on BP ultimate. Probably cause thats what the car was tuned on.
If your car is in good mechanical condition (02 sensor working, fresh fuel filter, good plugs and coild) then the maion things that will affect your economy are
1. City/Freeway driving
2. Lead foot or driving Miss Daisy
3. The tune
I found the biggest factor was my driving, and the fact i do 90% inner city driving.
I originally used caltex vortex until I was told it is actually only 96 RON! I then changed to Shell V-Power and noticed a difference in power and economy. Have never used BP ultimate (4c thing) but heard good about it. I get 430 - 450 kms down to empty (roughly 45 - 47ltrs) out of my R32 RB20DET 4-Door and thats only giving it the occational squirt as I drive it daily and need to save $$ and demerit points (one left due to two 80 in 60 zone busts in one week :D ) Only had it a year now and really impressed with the economy verses power ratio, big thumbs up to nissan!!
There are two different Vortex's, dark green 96 and white/gold 98 [bowser colours].
In summary
3. The tune
What so there is a fuel warning light, shit what a noob i didn't even know ive never seen it come on. Maybe i should do a Kramer off seinfield, but i will bring a jerry can when i run out.
In SA there is only one.. Its red at the bowser and 98 and does it for me! With the GTR gettin 400 out of 3/4 tank, that sounds wicked but I also found the last 1/4 goes real quick!
  • 4 weeks later...
hahaha
My little rb20det last year with a catback and pod filter never got 300km to about 55L fill ups with allot of throttle. But i cleaned my MAF and O2 sensour this year so when i get my new fuel pump and my car will start i guess i'll see what proper milage looks like when i break in my clutch and cant give it a shat-beating every day.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
