79 on 280ZX was EFI in Oz and if your looking at n/a, the best bits are N42, but the block has to be modified to front sump as all zeds are rear sump pans.
Don't be fooled, the old L28, makes good power if modified a bit.
A stock RB30E is rated at 114kW at the fly and an L28E is rated at about 103kW so there isn't heaps in it.
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3895099
will the sump off the L24 bolt onto the L28 block??
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3895625
RB bolts straight onto r30 crossmember wit RB mounts. no probs. hardest thing is gearbox mount.... then tailshaft....
This is true, but there is no clearance from the sump to the x-member. Thats what i had found in my case.
So you can do it this way, it does work, but no one will engineer it. So technically you will never be able to register that car.
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3898487
maybe... mine has ample clearance, it all comes down to the angle the motor sits on.. i cant c why it cannot be engineerd as there is no welding or modifications to the crossmember or the mounts..
ne way just got a blue slip wit rb25 numbers so to the untrained the motor came out in that car. true ?
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3898649
No Hi Horse this time ............................ just quoting FACT! but obviously it's not the answer you were looking for.
Before I answered you before I consulted an old business associate, he is a current RTA registered examination/inspection station and was an RTA examiner before that, so I guess he should know his stuff when it comes to NSW registration. They (RTA) have all the books for all the models and what is or isn't or was or wasn't fitted to the car, but, as I guess you know everything so do as you please.
JFYI, what happens when you have an accident & maybe injure or kill someone with your DODGY registered car and you are sewed for damages by the CTP insurance company??????? You would need millions behind you as any insurance would become null & void when they find your car is illegal.
But you know all the answers eh! and it will never happen to you? ha ha ha ha, go and grow up!
https://www.sau.com.au/forums/topic/220604-r30/#findComment-3900466
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
