Hi guys,
I took my car to the mechanic and he showed me that my 2 air flow meter plugs where disconnected.. He said that this would affect the air flow mixtures and possibly even power output.
Since my car isnt running properly now there is no way to test if this would increase my power now that they are plugged in.
SO what affect would unplugged air flow meters have on a cars preformance, just more fuel bieng pumped into the engine yeah?
https://www.sau.com.au/forums/topic/220638-installed-my-apexi-pod-filters/
rev limit = 2500rpm
I'm confused buddy, your saying that it would only rev to 2500 rpm?
But i was redlining it no problems, and it didnt feel like i had lost any power to be honest with you.
I didnt even notice the difference than from the stock air box.
with standard ECU and standard setup if you unplug the airflow meters the RPM will cap at 2500rpm and it will be limp mode
there is no way known the stock ECU would run std maps with airflow meters unplugged, its suicide and the engine has no idea how much air is coming in
double check again or maybe you have some wierd remapped std ecu with a map sensor hack / hks vein setup or something look
look for map sensors and crazy wiring if thats the case
and are you sure he said air flow meters?
it could have been 02 sensors, they are on the dump pipes, the airflow meters are pink labelled plastic things on the air intake pipes
if it was the 02 sensors, the car will run fine, it will just waste a bit of fuel on cruise and your economy wont be the best - no power gain by reconnecting them
double check again or maybe you have some weird remapped std ecu with a map sensor hack / hks vein setup or something look
Thanks man, i have gone an investigated everything you recommended.
First of all i must have a stock ecu as it has the Nissan seal is still on it:
But someone has cut a red wire from it and tapped up the end so it doesn't short anywhere.. what is this wire and why would they do this? take a look:
Also the i have circled in red the 2 plugs they found disconnected this morning:
I think we are getting closer to an answer thanks again!
see my pic - ive circled in red the true AFM plug, trace where the wires go
Good news i traced the wire back and its just the O2 sensor.
Ow well no extra power from plugging it in then.. :P
seen that red wire cut before on the ECU before?
cheers for your help buddy.
no worries - yeah 02 sensors unplugged wont cause harm, but you should plug them in, get some better economy
the red wire could be anything - its probably the speed cut wire, does it the stock ecu cap out at 180km/h on the track?
Yeah thats what i thought straight away too.. i havent been to the track yet to test 180km/hr speed cut.
I really want to head down to the track actually so i might become a SAU paying member since i hear they organise heaps of that stuff quite frequently.
The dudes got a PFC ne way so... :)
Actually dont have one yet, but i am trying to source one atm. Waiting on a few PM's from ppl selling on here.
Thanks for the confirmation of the speed cut wire too nismoid.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
