Subaru Forester:
Model: My07 XT Luxury, black leather interior
Milage:30K Klms
Transmission:Manual
Colour:Silver
Currently registered? Yes
Price:$35K ONO
Contact: PM Me
EOI for my 2006 MY07 Subaru Forester XT Luxury: Bought by me brand new.
Comes with black factory leather interior and the standard other XT luxury features. Car has done 30K Klms.
Have added:
* 20x8 inch DAAT D69 wheels with Falken FK452 245/35/20 Tyres. Cost me $3800 from Ozzy tyres. This is a street legal set up in NSW. Have removable black inserts. (One pic below with inserts in, one without)
* TEIN Forester specific Coilovers. Cost me $2000
* Zetty Cannon muffler attached to a pipe that bolts on at the diff. Cost me $500
Other than that, no other modifications. I have all stock parts to go with the sale: ie, stock wheels and tyres, stock suspension and stock muffler & pipe.
Looking for $35K ONO. Im located in Newcastle NSW. Rego TY50NZ
**I WOULD ALSO BE INTERESTED IN A SWAP FOR R34GTR PLUS CASH YOUR WAY**
Pictures below: Note - Ride height in the pictures is at the settings the coilovers came out of the box with. The ride height can be lowered much more than what is shown or heightened also.
PM me if you are interested.
Cheers
https://www.sau.com.au/forums/topic/220639-eoi-my07-forester-xt-luxury/
    • Just install a grease nipple into the centre of the outer steel of the FUCA. Make sure the bushes aren't long enough to touch each other underneath that nipple. Cut a few mm off each if need be. Then you can push grease in there while it is all assembled. That was the very first thing I did (to all 4 ends) of the FUCAs on my 32 when I put Whiteline adjustable bushes into them. They would squeeze the grease out real fast, and I could squeeze it back in faster.
    • @GTSBoy I found the issue (sort of) when I took apart the bushing again, it was completely dry inside! When I experimented with it, all the grease would push out when I would compress the bushings. I wonder if this has anything to do with me putting in the poly bush first on both sides and then pushing in the metal barrel. Maybe I should have put in the metal barrel first then the rubber bushings so the spread pattern is different.   It's fixed (for now).
    • Just redid that entire job. 4 hours, but tightened everything properly. Had to jack the rotor instead of having the car on blocks as there was no room for the FUCA arms to tighten and the j arm. All good now. Cheers for the help!
    • I would sell those side feeds before you hydra-lock a motor. I won't say too much about Yellow Jackets because I'll hurt people's feelings, however ask those that tune RBs day in/out what they think of them.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
