Skyline Parts (r32 & R33) & Random Car Parts
Item: 1x Nankang Ulta Sport Performance tyre 254/35Z R19 (19")
Item Condition: Brand new, never used
Price: $70.00
Item: 1x Skyracing tyre P215/65 R16 (16")
Item Condition: was in boot of my old commodore
Price: $30.00
Item: 2x R33 Nissan Skyline Castor Rods with bolt & nut
Item Condition: Used, off half cut with 70***km
Price: $20.00 each
Item: 1x R32 Skyline Drive Arm (From diff to hub assembly)
Item Condition: Used, has been damaged
Price: $5.00
Item: 1x R32 Skyline Rear Left Hand Side Hub assembly
Item Condition: Used , includes rotors suspension arms, stock & spring & drive arm.
Price: 70.00
Item: 1x R33 Skyline Standard Genuine Nissan Dump Pipe
Price: $30.00
Item: R33 Skyline Air conditioning Parts
Price: $100 for all parts of 35.00 each
Item: R33 Skyline Standard shocks & springs with tops
Item Condition: Used, out of half cut with 70,***km, no damage
Price: $40.00
Item: 1x R33 Skyline Side mount intercooler SMIC
Item Condition: used, includes all piping etc..
Price: $35.00
Payment Conditions of all items: Pick up, or postage at buyers expense :P
Reason for Selling all items: Garage clear out :(
Location of all items: Hame's Garage, Carindale, Sth Brisbane
Contact Details: PM, [email protected], or 0419761510 (can't recieve txt tho! :rofl::down: )
  • Replies 69
Item: 1x R32 Skyline Viscious Differential (VLSD)
Item Condition: used, but perfect condition
Price: $120.00
Item: 1x R32 Skyline Rear Sway Bar
Price: $35.00
Item: 1x R32 Skyline Green lable AFM
Price: $70.00
  • 1 month later...
  • 3 weeks later...
Turbo no longer for sale, hubs payment has fallen through so they back up for sale and there has been many offers on the brake calipers but no pick up as yet.
I will grab castor rods if you still got them and they are not leaking or no major cracks...
Give me a PM on full price to Melbourne - 3037 and your number.
Then we can organise payment.
cheers
Hey there bluey 33, will check the condition of the castor rods and get back to you.
Rear seatbelts have sold on - boostcrusing.
Front 2 x brake calipers also sold on - boostcrusing.
still plently left, hame
Can't edit first post so here is some more parts guys!! http://www.boostcruising.com/forums/index....howtopic=300288 (for pics etc)
r32 BRAKE CALIPERS SOLD, DIFF IS SOLD PENDING PAYMENT & THE r32 DOOR SEALS SOLD.
Item: 1x Apexi AFC
Item Condition: used, suits any japanese import. This is the original air fuel converter from Apexi
Price: $40.00
Item: 1x R32 Skyline chrome front bar garnish
Item Condition: used, gneral wear and tear, chrome
Price: $30.00
Item: 2x R32 Skyline GTS-T Rear cradle mounting brackets
Item Condition: used, no bending
Price: $20.00
Item: 2x R32 Skyline GTS-T rear suspension stabelizers
Item Condition: used, general wear and tear, bolts included
Price: $30.00
Item: 2x R32 Skyline GTS-T Rear cradle corner weights
Item Condition: used, great condition, bolts included
Price: $20.00
Item: 2x R32 Skyline GTS-T Rear Seat Belts & Buckles
Item Condition: used, perfect condition, no wear n tear or rips.
Price: $50.00
Item: 1x R32 Skyline GTS-T Turbo Heat Shield
Item Condition: used, great condition, bolts included (if i cant remember where i put them!)
Price: $20.00
Item: 2x R32 Skyline GTS-T Rear Brake Calipers
Item Condition: used, great condition, bolts included, these items are off an r32 gts-t 4 door (1989)
Price: $100.00
Item: 2x R32 Skyline GTS-T Rear Brake Rotors
Item Condition: used, plently of meat left
Price: $35 each or $60 for both!
Item: 2x R32 Skyline GTS-T Window Rubber Seals
Item Condition: used, great condition, not perished or cracked suit 2 door.
Price: $40.00 SOLD
Item: 1x R32 Skyline GTS-T Boot Rubber Seal
Price: $20.00
Item: 1x R32 Skyline GTS-T 93 model turbo exhaust manifold
Price: $25.00
Item: 1x R32 Skyline GTS-T 94 model turbo exhaust manifold
Price: $30.00
Item: 1x R32 Skyline GTS-T 93 model Side Mount Intercooler (aftermarket brand looks thicker)
Item Condition: used, great condition, no leaks
Price: $25.00
  • 4 weeks later...
1x R32 Skyline GTS-T ECU (manual-turbo) SOLD
more parts added & picutres of parts here --> http://www.boostcruising.com/forums/index....entry1283018402
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
