Skyline Parts (r32 & R33) & Random Car Parts
Item: 1x Nankang Ulta Sport Performance tyre 254/35Z R19 (19")
Item Condition: Brand new, never used
Price: $70.00
Item: 1x Skyracing tyre P215/65 R16 (16")
Item Condition: was in boot of my old commodore
Price: $30.00
Item: 2x R33 Nissan Skyline Castor Rods with bolt & nut
Item Condition: Used, off half cut with 70***km
Price: $20.00 each
Item: 1x R32 Skyline Drive Arm (From diff to hub assembly)
Item Condition: Used, has been damaged
Price: $5.00
Item: 1x R32 Skyline Rear Left Hand Side Hub assembly
Item Condition: Used , includes rotors suspension arms, stock & spring & drive arm.
Price: 70.00
Item: 1x R33 Skyline Standard Genuine Nissan Dump Pipe
Price: $30.00
Item: R33 Skyline Air conditioning Parts
Price: $100 for all parts of 35.00 each
Item: R33 Skyline Standard shocks & springs with tops
Item Condition: Used, out of half cut with 70,***km, no damage
Price: $40.00
Item: 1x R33 Skyline Side mount intercooler SMIC
Item Condition: used, includes all piping etc..
Price: $35.00
Payment Conditions of all items: Pick up, or postage at buyers expense :P
Reason for Selling all items: Garage clear out :(
Location of all items: Hame's Garage, Carindale, Sth Brisbane
Contact Details: PM, [email protected], or 0419761510 (can't recieve txt tho! :rofl::down: )
  • Replies 69
Item: 1x R32 Skyline Viscious Differential (VLSD)
Item Condition: used, but perfect condition
Price: $120.00
Item: 1x R32 Skyline Rear Sway Bar
Price: $35.00
Item: 1x R32 Skyline Green lable AFM
Price: $70.00
  • 1 month later...
  • 3 weeks later...
Turbo no longer for sale, hubs payment has fallen through so they back up for sale and there has been many offers on the brake calipers but no pick up as yet.
I will grab castor rods if you still got them and they are not leaking or no major cracks...
Give me a PM on full price to Melbourne - 3037 and your number.
Then we can organise payment.
cheers
Hey there bluey 33, will check the condition of the castor rods and get back to you.
Rear seatbelts have sold on - boostcrusing.
Front 2 x brake calipers also sold on - boostcrusing.
still plently left, hame
Can't edit first post so here is some more parts guys!! http://www.boostcruising.com/forums/index....howtopic=300288 (for pics etc)
r32 BRAKE CALIPERS SOLD, DIFF IS SOLD PENDING PAYMENT & THE r32 DOOR SEALS SOLD.
Item: 1x Apexi AFC
Item Condition: used, suits any japanese import. This is the original air fuel converter from Apexi
Price: $40.00
Item: 1x R32 Skyline chrome front bar garnish
Item Condition: used, gneral wear and tear, chrome
Price: $30.00
Item: 2x R32 Skyline GTS-T Rear cradle mounting brackets
Item Condition: used, no bending
Price: $20.00
Item: 2x R32 Skyline GTS-T rear suspension stabelizers
Item Condition: used, general wear and tear, bolts included
Price: $30.00
Item: 2x R32 Skyline GTS-T Rear cradle corner weights
Item Condition: used, great condition, bolts included
Price: $20.00
Item: 2x R32 Skyline GTS-T Rear Seat Belts & Buckles
Item Condition: used, perfect condition, no wear n tear or rips.
Price: $50.00
Item: 1x R32 Skyline GTS-T Turbo Heat Shield
Item Condition: used, great condition, bolts included (if i cant remember where i put them!)
Price: $20.00
Item: 2x R32 Skyline GTS-T Rear Brake Calipers
Item Condition: used, great condition, bolts included, these items are off an r32 gts-t 4 door (1989)
Price: $100.00
Item: 2x R32 Skyline GTS-T Rear Brake Rotors
Item Condition: used, plently of meat left
Price: $35 each or $60 for both!
Item: 2x R32 Skyline GTS-T Window Rubber Seals
Item Condition: used, great condition, not perished or cracked suit 2 door.
Price: $40.00 SOLD
Item: 1x R32 Skyline GTS-T Boot Rubber Seal
Price: $20.00
Item: 1x R32 Skyline GTS-T 93 model turbo exhaust manifold
Price: $25.00
Item: 1x R32 Skyline GTS-T 94 model turbo exhaust manifold
Price: $30.00
Item: 1x R32 Skyline GTS-T 93 model Side Mount Intercooler (aftermarket brand looks thicker)
Item Condition: used, great condition, no leaks
Price: $25.00
  • 4 weeks later...
1x R32 Skyline GTS-T ECU (manual-turbo) SOLD
more parts added & picutres of parts here --> http://www.boostcruising.com/forums/index....entry1283018402
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
