Gday everyone, this is my 1st post.
im seriously thinking of getting a R33 GTR.
What would be needed to get the car into the 11-10's 1/4mile ?
I have a very lame knowedge of skylines and have been a holden fan. Currently owning a VXSS tricked up and it runs a 12.2 on streets. but being 22 i need more. i want to see 11 to 10's and its getting time to sell the VXSS.
How much money would need to be spend on the GTR to see 11's ?
and whats a good imported R33 GT-R worth ? im guessing around 45?
any help would be AWSOME !!
thanks
MELV
https://www.sau.com.au/forums/topic/22066-help-getting-a-gtr-r33-into-10s/
  • Replies 56
A guy on this forum has a R33 gtr running ~10.4sec 1/4 miles
Name is Leewah, give him a PM and ask about the cost. My guess is about another $25-30k after purchasing the car. This would be a quality job that is still drivable
the r33 gtst that they use is up for sale for $40 000 something i think which seems like a lot cheaper way to do it to me, they also said that the car is capable of alot more but there not touching it cause its for sale its 400hp at the wheels its suppost to be the fast 2.5 in the country at the time
if you dont get much out of them try tony rigolies work shop i dont know where they are but the deal with some serious cars and they have a shop in sydney and on the goldy they have an r33 gtst that there trying to get 600hp at the wheels out of with similar upgrades good luck
400hp at the wheels is what I've got now with the NOS kit.
MELV
Well with a GTR you first have to decide what target you want. Do you want 11's, or do you want 10's
There is a HUGE difference and cost between the two.
Also a GTS-T is NOT a GTR, so dont compare the two....anybody.
its like saying "my mate bought a torana and did it up for a full cost of $50,000 and it ran 9's", and you spend 50k on a GTR and you get a clean stockish GTR.
If you want a clean GTR, a friend is selling his 33. Pm Leewah, or SIRVROOM.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
