Fitted the FMIC in place on the Stag and started the 2.5" piping to the stock piping to the SMIC. Front bar is fitted and there was no trimming or cutting required.
You heard right. Reo bar is untouched. Front bar has not been trimmed or cut. Unfortunately, I had to remove the extra driving lights fitted to my Nismo S2. It was getting dark and I was pressed for time, so no pics were taken. I am continuing and finishing the piping tomorrow, so I will take pics then, before removing the front bar, after removing the front bar, and then upon final completion of fabricating the piping.
:D
So happy with it.
https://www.sau.com.au/forums/topic/220673-fmic-fitted-to-stag/
Rubyn, thats really good to hear! Especially that you didnt need to cut ANYTHING.... Nice work! Looking forward to seeing the final pics, pitty you had to loose the extra lights, they were pretty unique
Get my pm?
Yeah, sorry got your PM, just busy with MY stag for a change LOL. I'll take pics of it, when I take the pics of the FMIC tomorrow.
I'm a bit disappointed I had to remove the driving lights, as thats why I got the 450x300x100 FMIC in the first place. Maybe I can relocate them after? But first and foremost was to avoid cutting into anything ... which I achieved.
When to Discount Mufflers this morning and picked up the bends and length of piping I needed. Best get too much than not enough!
:D
Here are some pics:
Looks almost stock (body parts and reo bar unmolested)
No cutting here!
Or here!
Isn't she lovely! :( (bumper fits back on perfectly, no gaps)
Watch this space ... Slide stage 2 hi flow turbo being fitted this week :)
ADD:
Finishing off the job yesterday, I took the extra time to pull everything off again and go about finding a way to mount everything back and up 1/2 inch in a bid to retain the driving lights. relocated the piping brackets and all. Good news is that it worked and I've just got to redrill the mounting holes in the reo bar and the driving lights will go back on. :)
The driving lights will cover up the reducers/clamps and I'm keen to lightly spray the cooler satin black for a more stealth look. :(
One advantage of having a swimming pool was being able to seal up the piping and dip it in water to look for leaks in the welding. :D Also, while I was messing about with the piping, found a clamp that was a tad loose. Hmm, may have been enough to be leaking boost.
Sounds like it was a good fit....nice to hear that ruby.....
Maybe thats where the "nismo" difference is with my Stag, with the exception of the Momo wheel, badging and front end ... looks like it had a fmic in mind. Very accommodating! :P
I'll hopefully fit the driving lights back in tonight. They'll be about 3/4 inch forward than normal, but you'd never know it.
Hmm, less than half the intercooler is obscured by the bar, but I don't want to go cutting it. Or moving the number plate ... wanna keep it looking stock. In any case, the exposed part of the cooler is still bigger than the smic, and with the cooler an easy 1 inch back from the reo bar, there should be sufficient air flow getting in there.
Edited by RubyRS4
nice fitment ruby, looks the goods! when can you do mine :P
When ...
... I get my Slide stage 2 hi flow fitted
... I get my SAFC2 fitted
... I get the Stag dynoed and serviced
... I get the 4 pot calipers fitted
... I get the Splitfire coil packs fitted
... I fit my new Ohlins coilovers
Then for the silver Stag ...
... turbo swap and fitment of dump pipe
... removal of suspension and fitment of Ohlins coilovers
... get Stag serviced
Thats just the cars, next (to keep GF happy) there is ...
... erect shed in backyard
... move shit into abovementioned shed
... erect second (larger) shed
... move 3 motorcycles into abovementioned shed
... make about 3 trips to the dump
Shall I go on? :(
So are you doing the piping yourself? are you welding or just using silicone joiners?
I have my own mig welder, so I've done it all myself. Just bought the bends from Adelaide Discount Mufflers.
I was hoping to handball the job to someone else, couldn't be arsed doing it, but did it myself to save $600 :laugh:
When ...
Shall I go on? :(
Ohh so youll be free next weekend? Excellent :laugh:
Yeah ... umm ... sure :)
looks good.
pics of underneath? clearance looks like it might be an issue?
What issue? The piping is miles above the legal 100mm minumum clearance. :D
Edited by RubyRS4
ADD:
Finishing off the job yesterday, I took the extra time to pull everything off again and go about finding a way to mount everything back and up 1/2 inch in a bid to retain the driving lights. relocated the piping brackets and all. Good news is that it worked and I've just got to redrill the mounting holes in the reo bar and the driving lights will go back on. :unsure:
The driving lights will cover up the reducers/clamps and I'm keen to lightly spray the cooler satin black for a more stealth look. :P
One advantage of having a swimming pool was being able to seal up the piping and dip it in water to look for leaks in the welding. :P Also, while I was messing about with the piping, found a clamp that was a tad loose. Hmm, may have been enough to be leaking boost.
yeh u shud spray it satin black n get black silicin hoses it'd luk heaps stealthy especially on a black car, i sprayed my cooler n all my engine black looks great....
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
