People im writing up a cruise for a friend, sorry if its late but oh well!!! LOL
8pm city west carpark, another open car cruise again!
Not tools, No prangs, No cops!
Its going to be raining so bring a rain coat, and PLEASE be carefull on the roads!
Thanks Kels
so dose any one no where te 2nd stop will be i turned up last nightto the ascot car park and on one was there ill try and get there tonight im in a gray r32 gtst with a vertex body kit hope to see you there and meet some of you im always reading these names but dont no any of you but (lunjiaow)vincent
Punctuation is your friend :)
And Vincent's a nice guy, I bought my grill off him!
Kel, I'm in for sure! See you then
Kels i'm so sorry i couldn't come...
i had a dinner that was planned late, Rhys did sms me though so i hope he passed on the message, sure to rock up to the next one!
i would've died in this weather tonight though bahaha
sorry i missed out few mate came around and before i new it it was passed 8 hope to go on the next one
lol we didnt leave till 9 >.<
not to mention im hopeless with maps so i follow people... if u follow me ur garuantted to be ....
lost
me needs a gprs,
workin on it...
i have a map but u know cant read that while drivin >.<
yeah was good ay,
i left after witfords and was heading down freeway into north bridge and got clocked doing 115, i mean for f**ks sake, dont they have anything better to do??
I think after that big hoon catch on friday night, they will be out inforce for the next few weekends....
So better be careful..
Ouch, bad luck Trent.
Sneakyazn, which R33 was yours? The P-Plater or the other one? I hadnt met you guys before
my R33 was the p-plater, also it had the ricey lookin thing hangin off the rear view mirror
<3 that car, so clean an imac ^.^
i got it from autoworx an had it for 6 mnths now, but i hear that ppl have had bad luck with autoworx... :S
Edited by Sneakyazn
yeah was good ay,
damn that sucks, :(
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
