ummmm VT 220kw was the 97 model
march 2000 VT Series II 300kw GTS which was a 5.7litre
i know because my boss bought one and took me for a spin in it around my 19th birthday
the 97 was a 220kw as stated.. which is most likely what it was u raced eric. i raced one in my 32 a while back (the 220kw) and beat it.
i think sxual he is saying that u said the VT never came in a 300kw flavour... which is wrong.
Originally posted by SXUAL
vt gts, never came out gen 3.  They came with a 5.7 but that was a stroker motor.  it was still a 215kw motor......  they had a hydratrak diff and 6 speed manual....   There not very quick.  VX came out gen3
Duhh, and then u say I haven't read the link??? Its common knowledge (for most) that the series 2 VT (YES VT!) GTS had the 300kw C4B engine (which is based on the LS1 GENIII).
In the words of Gary Coleman.. "whachu talkin' 'bout Willis?"
    • Thanks everyone! I'll take the remote apart to clean the contacts and see how it goes.
    • Balance to the force has been restored.
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
