hey guys, looking for a turbo upgrade.
looking for either a T3 from a VL turbo or an R33 RB25DET turbo. any similar sized turbos without massive lag (for RB20) also considered.
prefer melbourne as i would like to inspect it first.
cheers,
dave
Edited by dmr
https://www.sau.com.au/forums/topic/220715-looking-for-turbo-upgrade-rb20/
  nuR.spec said:
i got a recoed t3 for sale in vic pm me
you have pm.
  666DAN said:
VLT T3 will sit at the wrong orientation due to the wastegate being mounted into the dump pipe.
can you explain your theory more deeply?
i was told that it should fit on sweet, and that all i needed was a VLT dump pipe because the exhaust flanges are slightly different.
  SABBAi said:
Dave I have an R33 turbo here with 32 actuator. Housings rotated. Come check it out if you want. Don't want much for it. Has no shaft play.
can you please PM me what you're after for it. cheers!
  dmr said:
you have pm.
Hey Dave
Dave also here from Jap Ware house in Melbourne.
I have a couple in stock for you to look at, r33, r34 extremley clean, plenty for you to look at. We have more then one, pick and choose as you please.
While you are here you can check out out other stock also.
Give us a call
Dave
Jap Warehouse
61B Assembly Drive Tullamarine, VIC 3043
PH 9338 5277 or 0419 155 720 or 0402 453 527
We are open till late, so please call.
Speak soon.
  dmr said:
you have pm.
The flanges are exactly the same, but the way it bolts up to the turbo means the dump pipe is angled towards the side of the car, basically it's f**ked and won't fit :ermm:
I had one a few years back, not amout of frigging will get it to fit, trust me :happy:
  666DAN said:
The flanges are exactly the same, but the way it bolts up to the turbo means the dump pipe is angled towards the side of the car, basically it's f**ked and won't fit :D
I had one a few years back, not amout of frigging will get it to fit, trust me :D
my mechanic said that my dump pipe will have to be slightly modified to fit. the water and oil lines will also fit with a little modification.
did you have one on your RB20? how did it go?
Edited by dmr
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
    • Assuming that they will come off without damage at all.... i would have thought just pull straight up off the spindle with a something or other than can reach underneath. Have you searched for youtube vids of people doing similar on R34s or any other Nissan from the same vintage? They should be the same technique, in all likelihhood.
    • Keeping in mind that sandblasting is really aggressive on softer metals like cast alloy, and you can do damage that you might regret. For trash wheels, not a problem. For wheels with value/scarcity issues, etc.... perhaps a less aggressive media is a better choice?
    • Don't get all high and mighty. Experienced spanner wielders know exactly what effort is required to release an Oof.
