  • 5 weeks later...
Hey guys,
Got a cluster issue, every tacho works fine besides the rev tacho, it doesnt give the true reading and just jumps whereever it wants
Am i looking at a new cluster? or is this a simple fix?
I have the same problem!! Someone must know??
  • 3 weeks later...
  • 1 year later...
have u tried checking the connection in the back of the cluster to see if its loose or dirty? would start there i have same issue and its where ill be starting. im not in a rush though its only a tacho
Edited by chubs
yeh i'll have a look if its loose or something but it radomly still works every now and then..true its only a tacho buts its annoying to see it going crazy
yeah it is abit annoying lol with mine if i hit the dash a lil it usually works again but with bumps on the road it dies. should be an easy fix i know tacho and speedo are pretty common drama in 33's though from what i have seen.
bump this up.
k guys. my tacho stopped working thru a track day.
it will work when warming up but after a while it fails and drops down to 0.
if i hit a bump it will jump up...then back to zero.
My Power fc handcontroller tacho works fine......it leads me to believe its a wiring issue behind the cluster.. However it is all fine!!??
i have also replaced the whole dash cluster and this EXACT problem still persists. i have also checked all my fuses.....and they are fine
ANY HELP OUT THERE GUYS.??
i have used contact cleaner to clean the ecu pins, and the ignition module in the engine bay, and still hasnt fixed the issue.
its getting VERY frustrating !!!
i havent found a proper fix yet for my tacho but i notice by taking of the plastic cover off and pushing my gauge on the bottom right corner of it, it will work again. maybe i need a new tacho but i'm gonna drive around with the plastic cover off for now untill i get a new tacho. Not sure if it will work for you cuz my one was just shaking all over the place.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
