Well hello there im in Ireland and drive a 1995 R33 GTR mid night purple just hade the engine rebuilt and tought id say hi. heres a pew pics and spec. what ya's think.
And heres the spec list to
THE ALL NEW SPEC LIST
ENGINE / MECHANICAL SPEC
2.6L STRAIGHT SIX WITH A HKS 2.8L STEP 2 STROKER KIT(crank,rods,pistons)
TOMIE 280 PRO CAMS (11.50mm HIGHLIFT CAMS INLET AND OUTLET
HKS TO4Z SINGLE TURBO CONVERSION KIT INC ALL MANAFOLDS AND PIPE WORK
HKS STUD AND BOLT KIT
TOMIE OVER SIZE OIL PUMP
TOMIE SUMP BAFFLE
TOMIE CAM FOLLOWERS
HKS TWIN VALVE SPRINGS
UPRATED GEAR BOX AND TRANSFER BOX (drag spec)
NISMO N1 BLOCK BORED TO 2.8L
FULLY GAS FLOWED HEAD INLET AND EXHAUST POLISHED
SARD 800cc INJECTORS
APEXI POWER FC + HAND CONTROLER
APEXI AVCR BOOST CONTROLER
APEXI BOOST CONTROLER
PACE 100mm INTERCOOLER
TRUST RACE SPEC FULL DE-CAT EXHAUST SYSTEM (rated up to 1000BHP)
NISMO TRIPLE PLATE CARBON CLUTCH
OS GIKEN LIGHTENED FLYWHEEL
HKS TURBO ELBOWS
HKS ACTUATORS
TOMIE 1.2mm STEEL HEAD GASKET
MOCAL OIL COOLER
TOMEI UPRATED FUEL PUMP
NISMO FUEL REGULATOR
RB MOTORSPORT MODIFIED FUEL RAIL
TOMIE / OS GIKEN LIGHTENED CAM PULLEYS
TOMEI CARBON KEVLAR TIMING BELT
NISMO AIR FLOW METERS X 2
HKS HALF PIPE KIT
SPLITFIRE COIL PACKS
HKS TWIN INDUCTION KIT
HKS TWIN BLOW OFF VALVES
HKS WAISTGATES
TRUST FRONT PIPES
TRUST DE-CAT PIPE
OTHER STUFF
BEE*R REV LIMITER WITH LAUNCH CONTROL
HKS KANSI ATESSA CONTROLER
BLITZ POWER METER 3
18 X 9.5 CST ZERO HYPER WHEELS
AVON ZZ3s 265/35/18 FRONT & REAR
HKS SUSPENSION UNITS
EBC TURBO DISCS FRONT
EBC YELLOW STUFF PADS FRONT
EBC YELLOW STUFF PADS REAR
RB MOTORSPORT 1" WHEEL SPACERS X 4
TRUST CLEAR CAM PULLEY COVER
NISMO OIL FILLER CAP
NISMO HIGH PRESS RAD CAP
NISMO CARBON FIBER REAR SPOILER SIDES
SMITHYS CHROME FUSEBOX COVER
BLUE POWDER COATED ROCKER COVER, ALL TURBO PIPES AND RAD BRACKETS
NISMO GEARNOB
NISMO CARBON FRONT SPLITTER
NISMO STEERING WHEEL
NISMO GT BOSS KIT WITH HI-CAS
NISMO SMOKED SIDE REPATERS
NISMO GTR FRONT AND REAR STRUT BRACES
REINFORCED FRONT SUSPENSION MOUNTS
LIMO BLACK TINTED REAR WINDSCREAN , REAR QUARTERS AND LIGHT SMOKED FRONT SIDES.
IV ALSO HAD THE AIR CON REMOVED AS IT NEVER WORKED
AND GOT AN ABS BYPASS BLOCK MADE
THATS ALL I CAN THINK OF AT THE MOMENT BUT IM SURE I WILL HAVE FORGETON SOMETHING
thanks for reading
https://www.sau.com.au/forums/topic/220726-hello-from-ireland/
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
