Well hello there im in Ireland and drive a 1995 R33 GTR mid night purple just hade the engine rebuilt and tought id say hi. heres a pew pics and spec. what ya's think.
And heres the spec list to
THE ALL NEW SPEC LIST
ENGINE / MECHANICAL SPEC
2.6L STRAIGHT SIX WITH A HKS 2.8L STEP 2 STROKER KIT(crank,rods,pistons)
TOMIE 280 PRO CAMS (11.50mm HIGHLIFT CAMS INLET AND OUTLET
HKS TO4Z SINGLE TURBO CONVERSION KIT INC ALL MANAFOLDS AND PIPE WORK
HKS STUD AND BOLT KIT
TOMIE OVER SIZE OIL PUMP
TOMIE SUMP BAFFLE
TOMIE CAM FOLLOWERS
HKS TWIN VALVE SPRINGS
UPRATED GEAR BOX AND TRANSFER BOX (drag spec)
NISMO N1 BLOCK BORED TO 2.8L
FULLY GAS FLOWED HEAD INLET AND EXHAUST POLISHED
SARD 800cc INJECTORS
APEXI POWER FC + HAND CONTROLER
APEXI AVCR BOOST CONTROLER
APEXI BOOST CONTROLER
PACE 100mm INTERCOOLER
TRUST RACE SPEC FULL DE-CAT EXHAUST SYSTEM (rated up to 1000BHP)
NISMO TRIPLE PLATE CARBON CLUTCH
OS GIKEN LIGHTENED FLYWHEEL
HKS TURBO ELBOWS
HKS ACTUATORS
TOMIE 1.2mm STEEL HEAD GASKET
MOCAL OIL COOLER
TOMEI UPRATED FUEL PUMP
NISMO FUEL REGULATOR
RB MOTORSPORT MODIFIED FUEL RAIL
TOMIE / OS GIKEN LIGHTENED CAM PULLEYS
TOMEI CARBON KEVLAR TIMING BELT
NISMO AIR FLOW METERS X 2
HKS HALF PIPE KIT
SPLITFIRE COIL PACKS
HKS TWIN INDUCTION KIT
HKS TWIN BLOW OFF VALVES
HKS WAISTGATES
TRUST FRONT PIPES
TRUST DE-CAT PIPE
OTHER STUFF
BEE*R REV LIMITER WITH LAUNCH CONTROL
HKS KANSI ATESSA CONTROLER
BLITZ POWER METER 3
18 X 9.5 CST ZERO HYPER WHEELS
AVON ZZ3s 265/35/18 FRONT & REAR
HKS SUSPENSION UNITS
EBC TURBO DISCS FRONT
EBC YELLOW STUFF PADS FRONT
EBC YELLOW STUFF PADS REAR
RB MOTORSPORT 1" WHEEL SPACERS X 4
TRUST CLEAR CAM PULLEY COVER
NISMO OIL FILLER CAP
NISMO HIGH PRESS RAD CAP
NISMO CARBON FIBER REAR SPOILER SIDES
SMITHYS CHROME FUSEBOX COVER
BLUE POWDER COATED ROCKER COVER, ALL TURBO PIPES AND RAD BRACKETS
NISMO GEARNOB
NISMO CARBON FRONT SPLITTER
NISMO STEERING WHEEL
NISMO GT BOSS KIT WITH HI-CAS
NISMO SMOKED SIDE REPATERS
NISMO GTR FRONT AND REAR STRUT BRACES
REINFORCED FRONT SUSPENSION MOUNTS
LIMO BLACK TINTED REAR WINDSCREAN , REAR QUARTERS AND LIGHT SMOKED FRONT SIDES.
IV ALSO HAD THE AIR CON REMOVED AS IT NEVER WORKED
AND GOT AN ABS BYPASS BLOCK MADE
THATS ALL I CAN THINK OF AT THE MOMENT BUT IM SURE I WILL HAVE FORGETON SOMETHING
thanks for reading
https://www.sau.com.au/forums/topic/220726-hello-from-ireland/
