anyone got a engine hoist i can borrow,dont need straight away but may need to borrow for couple days to get motor out,then may need to borrow again for a couple weeks after that to put motor back in,got conrod to change on piston after motor cracked the shits other day
pm me if anyone can help in any way
still looking for a hoist anyone
im just after a water line for the stock turbo from the block on a series 2 r33. i have a new turbo and need to get a line made up for it, dont wanna go through the hassle of taking it off and being without the car for too long.
any help would be much appreciated!!
hey peeps i was wondering if anyone has a stock intercooler and uncut reo bar for an R33 S2 gts-t that i could borrow to get off of defect
you shouldnt need a stock intercooler. i went through regency with my fmic and it was fine.
to leave my intercooler meens i have a cut reo bar its the only way it fits so i need a stock one so i dont have a cut reo bar
um???? didnt even know i didnt have one... and they didnt check, mate went through with a cut one and they didnt check.. and we both had coolers.
the dude must have had a bad day just b4 i got there then
Looking to borrow a set of Stock rear struts to suit a R32 GTR for an ispection in 3 weeks, will only need them for a couple of days.
The back of my muffler hangs 15 mm to low and the shocks in there are stuffed as the previous owner has butchered them.
Preferably in the southern suburbs
can anyone please brighten up my day and lend me any of the following..
-stock r33 suspension
-stock smic
-series 2 r33 reo bar
-stock r33 skyline wheels with tyres
it would be much appreciated.
Edited by Nozila
got shocks and smic with piping got cusco springs not sure how low they are tho. might be putting them in mine this weekend? so if i do i will have spare stock springs aswell got stockies tread i think is legal but not 100% sure
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
