Hey all,
I just recently got a R33 from interstate and I am having a nightmare getting it through stupid regency!! Didn't realise Regency was so strict. Anyway, I need the following to borrow:
R33 stock turbo
R33 stock suspension
R33 stock castor rods
R33 stock spoiler
I am happy to give some cash/ alcohol for your troubles. If suspension is in good condition then I may even buy it.
Also if anyone knows of somewhere that I can hire the above parts then please let me know!!
Thankyou very much in advance
Franky
Hey guys ive been helped out by several people here already and was hoping someone could help me with a few last parts!
I need a stock R32 Steering wheel. I have my current one taken off so if i could just sorta borrow it XD that would be good also.
I also need an uncut reinforcement bar for an R32.
Im heading to Regency this Wednesday.
Thanks alot!
Eh Fellas,
need to borrow R33 GTR Stock rims to go through regency/compliance. Will pay cash, or free time at arena lol, up to u all.
Cheers.
You can borrow some r34 Gtt wheels with newish tyres if they will do.
Luke
Hey all,
After my nightmare with regency, I finally have my car back on the road :sick: . As a result I have some stock parts sitting in my garage that ppl can borrow:
R33 S1 stock steering wheel
R33 S1 stock front castor rods
R33 S1 stock spoiler
Also I have a R33 S1 stock turbo that I will lend out for $75 for a week. It will come with all necessary fittings such as pipes, banjo bolts etc so u dont have to run around for little bits and pieces. The turbo is in fairly good nick and should not get damaged easily but any damages will be borrowers responsibilty.
If you need to contact me urgently then email would be the best way: [email protected]
cheers
franky
  • 3 weeks later...
Hey guys wanted to know if anyone has a set of wheels i can borrow late this coming week pref thurs or friday??, doesn't have to be stock just anything 5 stud i only need them for a bout a hour and im willing to pay too if needed, thanks
Edited by /2on
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
