you can borrow mine Guy, just organise a time to come get them
Thanks Steve. I pulled the coil packs out between showers today and there was a lot of moisture at the base of the plugs. Cleaned and dried the whole area up after a short test drive it seems to be running well.
I'll run it for a day or two just to be sure, but hopefully the problems been resolved.
At some stage though new coil packs are on the cards, but Nissan want $233 each. Ill keep my eyes out for a set of spitfires I think. I've seen near new sets as low as $400, and around $550 new.
Hi, I am relatively new to the skyline world but are there any R33 GTR owners willing to test out a Power FC?
I have read the FAQs but it still won't turn over in my GTR :-(
I just want to make sure it is not my car which is the problem
Model is PFC GTR33L 020-0483
Happy to pay a few dollars/beer for your troubles
Those interested please PM me!
Cheers
  • 3 weeks later...
Need some stock springs for an R33 S2 to clear defect. Borrow or buy on those.
Also would like to try a stock AFM, O2 sensor and maybe an AAC valve to try to diagnose a few issues. I have cleaned all of these things using the guides on here.
I know the springs shouldn't be a problem, see how we go with the other stuff.
Cheers guys.
Edited by jase33
Does anyone here have a Yellow Plastic or Metal 20L Jerry can or two they could lend me for the weekend?
Needs to be diesel friendly!
Can pick up as long as its not woop woop
Cheers
Nigel
Hope Valley
  • 4 weeks later...
Just bought a S2 r33 from Melbourne and need some bits to take it in for ID check.
If any one could help me out I would appreciate it!!! Require the following:
- Stock IC and piping
- Stock Turbo, manifold, dump
- exhaust
- Inlet manifold and TB
- wheels with tread
- stock suspension
- s2 steering wheel
- stock dash cluster
Cheers
Hi all,
I'd like to borrow an english language R32 GTR workshop manual in the next few weeks. I can leave a returnable cash deposit with the lender if required. Happy to leave cash to the value of the manual.
Cheers.
Mike
  • 1 month later...
need to borrow these parts for an r33 s2 gtst:
stock intercooler mounting brackets w/ bolts and the intercooler elbows; pic related
getting my car inspected on monday at 10am so need it asap
  • 3 weeks later...
Has anyone got a good high flow fuel pump that I can borrow for 2 days?
Probably something that will drop straight in....
S1 R33 GTST - Looking at buying one, but want to be sure that it is the fuel pump causing the issue.
  • 4 weeks later...
anyone have a locknut key to suit the outside style lock nuts (not the key style) if that makes sense haha northern suburbs (gawler)
just going to steal some rims during the week........
joke joke got a car from the auctions and cant get the wheels off haha
get a cheap socket from supercrap and smash on it? or wont that work?
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
