yes, though there is the possibility of the water lines being different as rb20's had 2 possible sizes of banjos on the turbo. The r33 turbos all had 24mm headed banjos, r32's could have either 20mm or 24mm from memory.
It's easy enough to check before starting the job, just remove the heat shield and jam a socket on the outside banjo to see what size you have.
