Hey guys, so my xbox came up with the 3 rings yesterday and now its completely finished, my xbox has been chipped so I can't send it into microsoft for them 2 repair it, my warrenty has been voided. Just wondering if any of you guys know anyone located in melbourne who are able to repair my xbox, help much appreciated.
Cheers
Anthony
https://www.sau.com.au/forums/topic/220759-xbox-360-the-3-rings-of-death/
mine died yesterday, haven't had a single problem with it since day 1 when i got it at a midnight launch. But playing GTA on it the past few weeks it's been stuffing up occasionally and yesterday it finally bit the dust, ohh well not being a pirate FTW!!!
Hey guys
To fix this go on youtube and type in xbox 360 ring of death fix.
All it is you put 2-3 wrapped around the xbox 360 and turn it on, make it overheat(ie leave it like this for about 30 mins) take towels off and reset hopefully it will work.
Jamie
Hey guys
Jamie
This is a sort of fix that will allow it to run for another week max!!
Its stupid and a real fire hazard.
Hey guys, well i got my problem solved I found a guy who lives 15 minutes away from me, I dropped my xbox off to him yesterday, going to take around 2 weeks he said, $135 all up which I think isnt too bad considering his going to replace the parts inside and not some dodgey job comes with 3 months warrnty aswell.
2 weeks fark thats ages, why dont you see what MS charge might be cheaper and they fix these things in a day. So many people stress out about it i dont see what the big deal is, send the thing off wait a week and then play. They have put a huge amount of money into making sure these things leave in a reliable condition.
lol. thanks for that. I needed a good laugh this arvo......
Yeah that does sound stupid after reading it a second time.
But seriously they have put big dollars in warranty/parts etc for reliable fixed consoles.
these sniffing geek heads with out jobs playing 10hrs of xbox a day think its the end of the world when there xbox dies get all drepressed cos they have to share B.O. odor with another geek playing there xbox to so they get the sence of fullfilment for theday.
damm geeks. get some deoderant and some pimple cream... and stop snufling ya nose.. use a fvcking tissue already.....
I had a 360 fixed by some computer guys at South Melbourne market... they cut a dirty great hole in the side and bolted a fan to it... it worked like a dream... and then died again 2 days later
got a PS3 now... sooo quiet you barely know its on and you don't have to take the disks out with oven mitts on! clearly the better made console... but it took me 3 (if you count the repair) 360's to come over to the dark side
Theres your mistake you took it to the markets.
The ps3 is definately a better made console in terms of reliability there bullet proof, with the best blu-ray system available
however with alot less games (especially AAA games) and those 3rd party games not looking or performing as well, see below for proof
http://au.gamespot.com/features/6191251/in...;om_clk=topslot
Edited by Pattygtst
I wouldnt be taking those posts on that forum as gospel....alot of fanboyism crap if yopu asked me. Just browsing through some of the comments and some guy was going on about metal gear solid 4 coming to 360 and raving on about DVD9 discs like there new. Take that website and IGN with a grain of salt and make your own opinion.....
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
